Hello. First time poster here. First go kart build as well. I've bought a new 212cc Predator, and a #35 clutch/chain kit. Everything is going smoothly so far, these forums are packed with great info. My questions pertain to the outboard clutch install.
The engine shaft came with a 1-1/2" key on the shaft. Too big can't use it. The clutch has a built in key, but it's only about 3/4" long, allows for more wiggle room than I'm comfortable with, and doesn't appear to be enough metal to bear the load. And there doesn't appear to be enough room to use a smaller key in conjunction with the clutch. What to do?
I figured the set screws would remedy that, but it was suggested to me by someone that set screws would dig into the shaft, and I should just use a bolt/washer/lock washer on the shaft end. I got all that on, but that doesn't fix the shaft key worries I have. There's also about 1/8" more shaft than clutch, allowing it to slide back and forth a bit. Is that OK? If not, what do I need to get to space it?
Sorry for the lengthy post. Couldn't think of a short way to explain the situation. Any info would be greatly appreciated.
