20 series torque coverter question
arch252
I have a basic understanding of how a torque converter works but I don't have enough knowledge or experience to properly troubleshoot most problems with them so I really need some help.
I picked up a Carter go kart with a 6.5 hp Tecumseh. It had a torque converter with no identifying marks but there was no belt.
I identified it as a 20 series based on the V shaped driven pulley. It is a 7" driven with a 10" space between the center of the driver and the center of the driven. Based on that I determined that the belt I needed was a 26" belt, 3/4" wide.
The driver appears to engage just fine. I can see the driver expand as I increase the RPM's.
The belt appeared to install correctly, it rests loosely on the copper idler ring of the driver.
I really don't know how to troubleshoot the driven at all.
The belt is engaging as soon as I turn over the engine, preventing me from cranking the engine (unless I raise the tires off the ground).
Could this be a problem with the driven staying engaged? The belt is already pretty loose, I wouldn't think I need to loosed it even more, but am I wrong? Is the problem with the driver? What should I look for, how can I troubleshoot?
I'm currently trying to attach photos but am unable. I will keep trying.
arch252
Photos of the TC
Half-breeder
"Edit" button removed
Belts too tight...IMO... to tell if its too tight... squeese/pull the slack of the belt up to the ring and there should be 1/8 to 1/4" gap around the copper ring... not the part the ring slides on (remove driver clam shell half to verify gap). Bmikarts has a chart of what you're supposed to be running by measuring the distancing of the center of both shafts.
Also ensure the driven floats on the shaft, or wearing of the belt will be accelerated).
And there's the problem...
the belt you need is either
BELT 203586A
for a center to center distance from 9 13/16 to 9 7/8 inches
circumference: 35.14"
or
BELT 203587A
for a center to center from 10 15/16 to 11 inches
circ.: 37.11"
the 12-13052 you have (BELT 203583A)
will fit for a center to center from 8 5/16 to 8 3/8 inches
(circ.: 32.20")
so, yes, as Tihm said: your belt is too tight ;)
refer to this table for example:
http://gokartsupply.com/tcbelts.htm#203579A
arch252
I screwed up a couple of things, I determined the belt I needed was 32", not 26" like I said in the post. So the belt I got was 32". You're absolutely right though, that's not the belt I need. I went back and looked at the chart again and I have no idea how I came up with that belt! I knew I had a 7" driven with a 10" gap so that is clearly not the belt I need. Wasted money and a lesson learned. At least the problem is likely not something more expensive! Thanks guys!
