20 Series Torque Converter Issues
Smeeneezle
Chesapeake, VA
Hey DIY Go Karts, I finally got my Carter 2336ZX 2 seater on the road with a fully built (my first personal build) Predator 212 and it has a 20 series torque converter on it. Laugh now it you know where I’m going with this. My engine is turning well over 6000 rpms as I have a Trail Tech Vapor (love it!!!) installed which is wrapped around my upgraded msd spark plug wire and boot connected to an upgraded coil.
Well before I took this thing out for the first good romping I didn’t realize that this series torque converter was not built for this amount of rpms. I rode it for hours with different kids as my passengers and it rocked with no probs. Later that same day my buddy stops by and I let him take it out for a spin. He rode it for like 2 minutes and the dang thing cut off on him while he was trying to turn around and head back. He proceeds to hop off and try’s to pull the cord to restart it and he noticed that it tried to pull away from him when he pulled it. I run down there and notice that the torque converter is stuck in the engaged position. We push it back to my garage and I take the torque converter driver apart and notice that the weights were in fact stuck in the engaged position and twisted slightly which is what was keeping it from retracting. I also noticed that one of the two garter springs was flattened in a couple of sections. It was after that when I started to research the issue that I encountered and discovered that the series 20 torque converters are only rated up to 3600 rpms which explains a lot.
So, with all that being said, my question is what are my options from this point? I’ve seen the upgraded aluminum weights and different colored garter springs (which seem to only increase or decrease the actual engagement rpm but I haven’t come across and data on what rpms each colored spring goes UP to) which I’m hoping will assist me in this situation as I can not afford a series 40 torque converter at the present time. So, do I have any hope in modifying my series 20 torque converter or is it a must to upgrade to a 40 series or even higher options then that? Thanks in advance for any and all advise/recommendations/comments/suggestions that you all may be able to offer me. Have a great day!!!
Hello and welcome...
Since you new here... Could you modify your post so it can be read better.... People see a wall of text and its hard to read...
Post some pics...
The springs should be about straight when you take them off the weights.
If not, the link below will come with springs and weights and will cost about the same.
Unless you are going to upgrade to stiffer springs, or want genuine comet parts... The complete unit is a pretty good deal.
https://www.walmart.com/ip/20-Serie...9223&wl11=online&wl12=757522382&wl13=&veh=sem
Here is a cleaning / maintenance video.
https://www.youtube.com/watch?v=fn6160DxW2E
https://www.youtube.com/watch?v=C9yPHtfJO9w
