2 stroke fuel mix
fowler
Bullsbrook West Aus
haveing never played with 2 strokes much i gotta ask about mix ratios
my old victa wants 25:1 ratio, thats want iv always used
but my new still wipper snipper wants 50:1
and it came with its own oil
not surprisingly the oil can rekomends 50:1 mix
i used that oil to mix up some 25:1 for the victa
now the bastard will not start for for nothing
so after going though all the possible causes i gave up on it for now
then i put that same fuel in an old 4 stroke engine (runs better on 2 stroke)
then it started playing up and died
so i swithed it to straight and its fixed
clearly the fuel is bad
but its not the petrol thats bad its the oil
my question being
does the wipper snipper take a weaker mix because it requires less lube
or is the Still oil just stronger and u dont require as much in the mix
or lastly is the Still oil just jumk
exenos
Project Nut
Hmmm, that's a little odd. You should be able to run just about any engine, including 4-strokes on any oil mix up to about a 10:1 mix without any problems(well asides from the smoking). I test fire just about every engine I have with a spray bottle of 20:1 and haven't had a problem yet (knock on wood).
Try a bit of the 50:1 mix in the victa. It won't harm the engine for the few seconds your going to be running it to see if it's the mix or not. Also make sure you didn't accidentally use the wrong units, I've used the number of oz's for a follow of 50:1 mix into a L of gas by accident. Took me a second to figure out why the heck my engine turned into a smoke machine. With a mix like 20:1 you'd end up with something like 6:1 and that might be what's causing it not to run.
As far as the oil being bad, I don't think that would be the case. Oil doesn't separate like gas as far as I know. Most people say that you can run a slightly lower mix of oil to gas with the new synthetic oils because they are a better lubricant than the old mineral oils but I still wouldn't run 50:1 for any extended period of time. The older engines do benefit from a bit more oil because of their design (or so I have been told). If it runs on the 50:1 I'd give some 35:1 a try and go from there.
Edit: Dam, sorry about the book. Hope I didn't ramble too much
ak99
Queensland, Australia
Victa's, for some reason have always been recommended to run at 25:1.
Maybe they think us Aussies love the smell??
Anyway, I've run my Victa's at 40:1 for years and have never had a problem.
I fill my blower and trimmer from the same can and they are 40:1
If I ran them at 25:1 they would have blocked exhaust screens in no time.
I have heard stories of other people running a Victa at 50:1 however I haven't done it myself so I won't suggest to do it.
40:1 is fine though.
Cheers
fowler
Bullsbrook West Aus
Intrested enough the victa web says run 25:1 in most cases
Unless u run their special v2 oil
Then run 50:1
I'll try the 40:1
Cheers
ak99
Forgot to mention, I use Castrol 2T oil.
Don't know if it's good, bad or otherwise..... I've never had any probs with it and it's cheap.
Cheers
