~18hp lawnmower vertical engine to horizontal
BeaterofAincrad
2018 Build-Off Contestant
Vermont
This is a project that, if I execute, will be in a few years. So the other day an idea came to mind after after reading about using a ride on engine on a gokart.
In the transmission of a dump picked ride on I have, there are 3 bevel gears used to power the axle.
So say, in theory, if I somehow got one mounted on the engine and made a “transfer case” and bolted that to the engine.
Then had a jack shaft horizontally through that with the other bevel gear on it. Would the gears be strong enough to power the axle without shearing?
I would most likely have some sort of torque converter on it.
Atlanta, GA
You'd have to know how much power (torque) the engine was producing, and how much mass you were wanting it to move (and where, for example: rock crawling?).
BeaterofAincrad
Vermont
I was thinking of a frame something like this.
https://www.spidercarts.com/downloads/granddaddy-go-kart-plans/
And it would be used on relatively flat ground, around our yard(we live on a hill), and if possible in the woods behind our house(isn’t too rocky but still on a slight incline and would have to make it up this).
anickode
S.E. Michigan
What type of engine is it? Some of them don't require very substantial modifications to change over. Others do.
BeaterofAincrad
Vermont
I see, I’ll have to look into those when/if I start working on it. I’d like to avoid buying anything too expensive though.
