18hp b&s govenor removal
DJEEPER
Does anyone know how to remove the governor from a briggs and stratton 18hp opposed twin?
Honestly? Same way as every other industrial engine mechanical governor. From engine to engine, the parts may look a little different but it's all the same. Dig thru the stickies in the Engines section and read up. You should have no problem applying your newfound knowledge!
(Bring a torque wrench)
DJEEPER
Next question is do you think the flywheel can handle all of that extra power?
exenos
Project Nut
You would have to split the crank case I believe and you may not want to get into that. Try adjusting the external governor parts. I think you can adjust Briggs governors up to around 4200rpm?
DJEEPER
HMMM.... I would really rather leave zee govenator in there... I was unaware it was adjustable.
*facepalm*
time to get some reading done! :)
The range of external adjustment (according to the manual) is only +/- 100 RPM. I will have to get back to y'all on this, when I attempt to set mine to 3850 according to the rules...
