karl
Here is my situation
I have a hemi predator with ,
Stock length arc rod
Arc flywheel with stock key 32 degree advance
Arc filter adapter and top plate
Might as well be sponsored by them
18 lbs valve springs
Mod 2 cam
Header with Rvl muffler
So I am running stock compression ratio.
It pulls good but I want more. Increasing compression ratio and bigger carb should help alot.
I still want to run pump gas (93 octane)
So my options seem to be mill the 18cc stock head .050 or get a gx160 head.
On ebay you can find bare heads cheap.
I am confused about a few things.
From my searching, new and old style 160 heads are different. From the pic in the ad it looks like the old style. Im no expert.
Then there is shrouding valves , or spark plugs .I am clueless here.
Idk, flatheads are so much simpler.
What I want to do is take valves , rockers, and all from my current head, put it all in the ebay head, and bolt on my motor.
Other then dowel pins, and valve cover, what issues might I run into? Is this a good idea?
Should I port the head, or run as-is?
I need some education on these chinese ohv things.
Mod 2 cam
