yea do homework theres a lot of questions here answered in the stickeys or something that are just...... as long as you don't post questions like how do i remove my gov then when someone tells you how you ask "wheres the block"? i almost cried reading stuff like that, lol. good luck with your engine though tons of info on the web, main things are gov, flywheel, carb jets, air filter, header. then you get into more stuff like compression, bigger bore cylinders you know stuff that basically makes the engine a completely different engine
