12v power from a gx390 clone?
Camdat67
Riverland. South Australia
Hi.
I want to run a thermo off the gx390 clone in our dirt kart. The CVT gets a little bit too hot if the buggy is hammered with continual on/off throttle applications and this is bad for belts.
My gx390 clone is pull start only so no battery or starter, but I was hoping that there is a 12v output somewhere there I can tap into to run a small thermo. I figure that my honda XR600R has no battery or starter, but runs 12v accessories, so there might be hope. If anyone knows if its possible, please let me know.
Cheers.
Simon (Australia)
slideways
Nothing there. The two options you have are to buy an electric start kit which will have a new flywheel and charging coil and a starter. Even then it doesn't provide constant voltage, it depends on rpms.
Best option is to get a lawnmower battery and mount it up on the kart with a fan to cool the cvt. I still doubt this will be the cure to your problems though.
redsox985
PA
I doubt a fan would work. A moving kart would get plenty of airflow. A thermometer may be the only way to save the belts shutting it down when it gets too hot.
