12 HP Tec. Governor
qtband
St. Louis, MO
I have attached a picture of the governor arm. What does the screw that is circled do? Is it a speed adjustment? If not, what is the easiest way to slow down this type of engine? The owner wants to let their kids drive it.
The screw is definitely a stop. If you follow the linkage to the carb, you will be able to tell if it's a high-speed set, or idle. I can't remember offhand, my current Tecs don't have them.
As always, the BEST way to control speed is gearing. Rev it too low, and you're having Kentucky Fried Clutch for lunch.
