Brianator
Gettin' er done!
Sounds like you're having a rough go there fella! Backfire out of the carb is typically due to the crank/cam timing being out of whack which believe it or not, valve lash can play a minor role in that. When you're cleaning the carb are you spraying carb or brake clean through the orifices? My go to for physically cleaning jets and small orifices are bits of guitar string, they are stiff enough to not fold under pressure but flexible enough to get into awkward spots. Another big thing to consider is spark timing so it might be a good idea to check the flywheel/magneto key, if it's even partially sheared it will throw the timing off.
