Hey guys, i have a new project going on here, I picked up a generator with a blown engine (10hp tecumseh) and a (supposedly running) 10hp tecumseh. Anyhow i checked the compression on the good engine and it was only about 60 psi. So i opened the engine and the cylinder looks excellent (some hone marks are visible) but the valves weren't seating all the way at TDC, so i removed the springs and had the weirdest problem ever. The intake valve's bottom was too big to fit out of the valve guide, weird right? The valve looked unburnt, so i left it, i lapped the exhaust valve (burnt to hell) and gapped it. After reassembly it still has only 60 psi. It sparks, has compression, and i spray gas in the intake and it doesn't even try to fire. I am using the electric starter. I tried the pull start but its very hard, im thinking it may have a sheared key. Any opinions im stuck
