10 hp tecumseh engine
zztop
Hello there everyone! I had a question about a tecumseh 10 hp engine. I am building a fairly large mini bike and have built a bracket for a 10 hp tecumseh engine and already have the engine. I order a comet 40 torque converter for a #35/#41 chain (interchangeable) i was going to do the assembly today and realized that the engine i ordered did not have a 3/4" in keyed bore that would fit my torque converter. It instead came with a pulley attached by a small allen head bolt. Do i need to send the engine back? is there another torque converter I could use? or would it be possible to change the spindle......? I would really appreciate the help
anderkart
Surprise Arizona USA
Yes the Comet 40 series Driver is available in your choice of 3/4" OR 1" bore.
If you want to use that engine, contact whoever sold you your converter about exchanging the driver for a 1" bore model.
Or you could purchase the part to make it fit 1" bore.
Here's the part you'd need:
http://www.mfgsupply.com/gomini/gom...q40/gominiclutchtorq40driveparts/203023a.html
zztop
Spindle
thank you so much for all your responses!! I have put up a link to the photo of the picture i took, can anyone tell me what kind of spindle this is exactly? I was hoping that i could get a converter to fit it instead of shipping it back to the manufacturer and waiting several weeks. http://tinypic.com/r/2wn4k2e/8
anderkart
Your 'spindle' pic is a part we refer to as an engines output shaft, Its also sometimes refereed to as a PTO.
If the smaller/end portion measures exactly 1-inch across, and it also has a lengthwise 1/4"-wide X 1/8"-deep slot/keyway machined in to install a key, and also has a threaded hole in the very end to install a bolt: A correct term for that part would be a crankshaft with a keyed 1" output shaft.
The link to your pic took a long time to load, so I've posted your Image here for others to more easily see:
