10 hp Tecumseh engine on kart.
redsox985
PA
Well, how much grunt do you need? And, does that first link have a straight, keyed shaft?
Bluethunder3320
the 5.5 is a snowking engine. meaning yes it has a keyed shaft, but the throttle is preset. on engines that i have seen are preset, there IS NO THROTTLE. the governor is directly connected to the carb, and this means once you start it the motor will stay at a constant 3600 RPM. and your kart will take off down the street.
if you got the money for the 10HP GET IT! its a flathead tecumseh. not a snowking engine either. plus its drilled and tapped, keyed shaft. its expensive but its a GREAT engine. i have seen the internals of a 9HP tecumseh flathead and the rod is pretty beefy. exept it was broke because no one bothered to put oil in the engine. what a shame because it was brand new........
EDIT: oops saw this:
"This may not look exactly as pictured, this engine will come with an Overhead Valve"
ok, it wont be as good as a flathead tecumseh, but should be fine anyway... bummer tho.
EDIT: oops, shaft on the 5.5 turns out its stepped.
r97
Measure twice cut once
Massachusetts, USA
i would suggest you search craigslist for an old 8 or so hp engine to fix up. you can also go to local lawn mower shops and definitely yard sales, your bound to find one. just make sure its in reasonably good condition, has a proper shaft and that you are sure you can get it going nicely!
South Kart3377
Kart designer
Va
That one has a 1" shaft and is useable. Displacement is probably around 250cc but truly is unimportant. Rated hp is 7.8 which is a more useful figure for our purposes.
South Kart3377
Kart designer
Va
What wil hp be when straight piped and air filter, govener out!!!!!!!!!!!
You forgot "Rejetted".
In theory you could safely add 1-2 more hp after those mods are properly done.
Without rejetting, the improved flow of the intake and exhaust are at best a total waste of time, and at worst, a lean-running condition that'll cause problems.
Bluethunder3320
the tecumseh is 319cc i believe. go check your craigslist for something first. i saw a 7hp vanguard for $150.
South Kart3377
Kart designer
Va
18lb valve springs, Flywheel key, govener out, air filter,straight piped, rejetted, al. Flywheel, billet rod, any thing else?????
