Old man needs governor help clone (Greyhound) 212cc
Thats correct, when it hits the tap it is running too fast. It has to slide under the tap to slow down. Is that the way it is suppose to work?
The lever runs right into it on my stock 212cc Rotaderp Hemi model 60363. Mine has a cable clamp there. That’s full throttle IDLE SPEED with that lever pushed forward in the kart’s direction of travel. My mistake.
Make sure you have a stout throttle return spring there.
Kablooie
Yup, I watched that earlier. There must be something out of wack, because when it hits the stop it's not WOT, but it is running too fast to NOT engage thw clutch.
