I have a brand new 2008 Greyhound 6.5hp engine I just put on a go-kart for my grandkids. I took off the govenor linkage, then changed my mind, afraid the grandkids might launch into a tree. I put the linkage back on, triple checked the linkage, adjusted the govenor. Here is the problem, with the engine off the carb butterfly will not automatically return to idle position. When started it's full throttle. I'm not sure about the govenor shaft coming out of the engine, it moves freely when not running, moves about a 1/4 turn, should it have some drag? I'm not understanding why the butterfly won't close, I can push it shut with my finger. when I move the throttle the butterfly does not change position.
to DIYGK.
