Adding fuel gauge to shallow tank
ukrkoz
We acquired a Trailmaster Blazer 200R with 212 engine.
It came with a gas tank with no fuel gauge.
Problem is, tank is wide and shallow, only 2.7 inch depth and 3.7 inch from the neck top to the tank bottom.
I spent days searching for gauge that might fit and apparently, they do not exist.
Any ideas? I can't really get my hands or even tools inside the tank, obviously. Can't drill through the cap as it has some screw on breather thing on the inside.
Tank is very thin metal, so trying to tap into it in sealed manner not happening. Any caps with built gauge are way too long. I mean, yes, unscrew the cap look inside, right? Except that I work normal hours and 10 yo grandson likely won't even be able to unscrew the cap - if he remembers to do it.
Thank you
Sounds like it will be a lot of trouble to try get a fuel gauge and get it to work. Do you need a fuel gauge? Maybe you could be satisfied by just eyeballing it all the time?
ukrkoz
Oh, I can eyeball it fine, except that I am not there all the time eyeball it. Neither my wife nor grandson will. And that leaves him with a good chance of getting stuck somewhere half a mile away from the nearest can of gas.
I start considering replacing the entire tank with one that has fuel gauge.
Use an emergency-use bottle of fuel. A 1 liter is probably more than enough. If the main tank runs dry, have the youngster dump in the emergency bottle and head straight home. I like the Optimus or MSR brands. Put the auxiliary fuel bottle on the kart with the aid of a tool tube. Use non-ethanol fuel for best results but it would be a good idea to cycle through the emergency fuel every 6 months or earlier, and refresh the bottle with fresh ‘juice'.
I like this site for the tubes and he also sells the jugs to go in the tubes, in a little DIY kit. You might do better sourcing the parts individually on Scamazon or what-not, not sure: http://www.thetooltube.com/mototubes.html
I agree with W.T.R. Teach the grandson, 10 years is old enough to top off the tank every time and check the oil, etc.
Sparkwizard
Richlands ,NC USA
Maybe drill a hole in the top and bottom, install a sight glass. Clear vinyl tubing is cheap and easy to install. Two hose barbs, a dab of sealer and 6 or 8 inches of 5/16 tube.
Get a fuel petcock from a moped or small motorcycle with a "reserve" lever. When it runs dry from the main supply, twist the lever and restart, go home.
Add a small reserve tank and a cutoff valve. When it runs dry, open the cutoff valve from the reserve tank and have that gas run into the main tank.
Like this.
