Predator 212 gov delete support mods
Ls1Garage
I wanna take the governor off my non Hemi predator 212 I plan on putting a different coil on it to limit the rpm I also want to upgrade the valve springs to eliminate valve float but not rev it high so I don’t explode the stock flywheel, I’ve tried looking for a good answer but I couldn’t find one. I know that the valves float between 5000-5400rpm I want some recommendations for a rev limiter around there and let me know about any opinions or recommendations you guys got!
Ls1Garage
I want something thats safe and reliable so I don’t blow up my flywheel and I plan to install stiffer valve springs anyways since there cheap enough.
If you don't change the flywheel ( and the rod ) just keep the stock valve springs in there. That 5400 to 5500 rpm range where they start to float is about as fast as the factory stock pieces will handle.
Ls1Garage
I still plan to do springs since there cheap enough, what rpm would you say my rev limiter should be? I’m going to be ordering one. Also I just wanted more options on the flywheel and rod because some people say it will blow up if you look at it wrong or some say 6,000 is borrowed time not that I’m going to rev it that high.
I plan to just do springs I’m not some kid trying to spin his motor to moon just trying to make it safe and reliable
These are contradictory statements. Safe and reliable would be NOT changing the springs.
Dont change the springs until you change the flywheel and rod. Youre just asking for a chunk of cast iron in your thigh or back.
