v8 2 stroke build
dan
Austraila
hi all im planing to build a v8 2 stroke engine from scrach lol :D. i might sound crazy cus who would build a v8 2 stroke engine completey from scrach :roflol:. well i would lol. im most likey goin to run cbr600 pistons and make my own con rods and fit berings too. in order to do this i need to make my own crank shaft. so if i use the cbr pistons and if i make it the same stroke as a cbr600 ill end up with a 1200cc 2 stroke v8. this thing will scream and be a rocket on the right applaction. lets see how i go.:cheers2:
thanks. Dan
dan
Austraila
change of plans i cant find my cbr600 pistons so i was thinking of buying pocket bike components such as: pistons, rings, conrod, cylinder, maybe cranks and mod then to accept 2 con rods per jernal and joining them all together. then all i need to do is make a bottom end and sort out ignition. i think a 400cc 2 stroke v8 would be kool to say you built it lol.
Smokey Unik experimented with building full size 2-stroke/V8 race engines back in the 60's.
He said: Twice the power at half the weight.
mike75925
thinker and tinkerer
Alto, tx
so you are gonna make 4 2stroke harleys hunh? i definitely want to see it. are the cylinders going to be removable? i had two cox free flight engines, i thought of making a v-twin from. never did it. anyway, pistons sre around 20, i don't see the cranks available on partsforscooters.com. you should be able to find donors in the scrap yards. i paid 35 for one with no body. engine was good though
Kaptain Krunch
Pro Junk Collector
vermont
I'd say grab some L/C sled engines, use the jugs, pistons, heads, carbs etc and machine your own bottom end and crank.
I hope you know your way around a machine shop, because making an 8 journal crank/crank case for a two stroke is going to be a job and a half.
TurtleMann14
Insane plan member
West Virginia
i hope you know cnc.... that's a ton of milling
and if you have two pistons per crank case doesn't that mess up the fuel and air delivery?
you will be making your own crank... that's that
Kaptain Krunch
Pro Junk Collector
vermont
Yea i would think with a two stroke, two rods per journal would mess up fuel air...but i dont know. I've always seen multi-cylinder two strokes with sealed crank cases for each cylinder.
Mike, why would you have 9 journals in a 8 cylinder engine? that makes no sense.
TurtleMann14
Insane plan member
West Virginia
sealing each piston to itself...
a true v8 i don't think is possible
more like two banks of in-lines or a compact in line
you would be better off making something like a v4 at first
mike75925
Alto, tx
the crank has to be supported on each end. if running 8 slots for pistons, you need 9 journals (for the crank to rotate). since he was saying run 2 per, that would be 5.
BriggsTwins
Pittsburgh pa-Tallahassee- fl
hmmm, look at it this way, if you make the block and cylinders as four strokes then all you have left to for is make the heads which is more simple than fighting with crankcase pressures and fuel delivery... using jugs off of a bike, all you have to do is machine the fins away from one side to join them together, and get a NICE cooling system for it
timing and camshafts would be greatly simplified but you still run the issue of making a system to feed oil, Intake manifold and having a decent set of bearings...
TurtleMann14
Insane plan member
West Virginia
cam shafts??? what cams?
are you talking about a two stroke with valves? that would be plausible, but the head work would still be hard
probably more hard than case work
and the valves would be opening twice as many times as the four strokes so he would get valve float sooner, right?
then again he could have a two stroke like the Detroit so that the only valves are for the intake
(possibly supercharged two stroke)
(but then he would have to go with dry sump)
freakboy
the names 'mater
hick town
cam shafts???
the valves are for the exhaust the air goes in through the cylinder wall and then the fuel is just injected in to there... just sayin.
TurtleMann14
Insane plan member
West Virginia
:/ guess i had that a little backwards
you sure? idk it would just make more scence to me if the exhaust went out the ports on the cylinder
i can't find anything on it
freakboy
the names 'mater
hick town
probaly not the piston goes up pushes gases out while theres air on the botom then it keeps goin up valves close injector goes and bam...
