Can you tell me where the governor is, and how to make a header and what to do with it. Thank you!Remove governor, make a header for it.
Or if doing a 100ft burnout with the front end straight up is what you call fun a large snowmobile engine swap is just what you need!
A header is a neW exhaust pipe, just make one that is very high flow. The governor is inside the crankcase.
I suggest you read up on 4 stroke theory.
