Thepartsguy
I thought picture one he was sporting a backpack mounted flamethrower but it’s actually a belt fed browning.
Thepartsguy
Clearly the car is AI! AI is gonna kill us all. How did the T-Rex aim the rifle? Clearly its arms are too short to get the rifle near its face to be able to aim it.
It might not kill us all but there is a good chance that are first defense against a rise up and hostile takeover is destroying all power station local/global.
Would force us to kick ourselves back into the Stone Age in my opinion. The thing about the movie style AI is the robots never stop to charge a battery or they just blatantly skip past the infinite power source the robot seems to run on.
Humans have a battery called a heart and it runs off food/water and If that specific human lives to be 100 years old that is a battery that is proven to work for 100 years off food/water alone.
Ai making a heart style battery would directly go against it’s survival protocol as it knows very wellIMG_9432.jpeg
Great triggers! I put a Timney in one of my Mosin Nagants. It's great and well worth the money.
Maybe you can help me. Have a Mosin 91/30 PU sniper with a horrible, heavy trigger. I suspect it was re-arsenaled for a new trigger then put back in the rack, otherwise it’s unexplainable. I don’t really understand how to lighten the trigger but I should, you know, being a milsurp guy.
Would prefer doing it in a period-correct way but it probably deserves a Timney on account of it being a snipper weppin.
You can lighten the trigger pull weight by almost half by installing a spring behind the trigger and adding a washer/shim to the sear spring. The sell kits for this.
Also polishing the bolt and sear help a ton.
Yours has the bent bolt right? Most snipe versions did and I've also wanted one. There are ways to cut the bolt handle of and reweld it on, or the sell kits that bolt on. Of coarse buying a used bent bolt version is expensive but that is they way I want to go. Just waiting for the right one to pop up for sale.
OneTimeUser
We Don't Rent Pigs
Texas
I'm in the market for a new EDC pistol. Retiring my Sig P365 and Springfield XDS .40 as an EDC. Keep in mind I want to keep it sub-compact to be easily concealed. I have my full framed pistols which are nice in the winter because I can outside waistband carry and still keep it concealed. My XDS has been great, but the .40 cal is slowly going away and the 7 round capacity is just too outdated and with all these 15 round 9mm options out there and the advancements in 9mm ammo options out there I'm fine with 9mm. Just curious what you fellas like. :cheers2:
Just out of curiosity, how come you are retiring the Sig 365? I went through at least half a dozen pistols until I found the 365. It seems to me (and a zillion others) to be unsurpassed as a carry pistol.
It was the SAS(Sig Anti Snag) version of the 365. Shoots great and accurate, but the sights suck at low light. I added a light laser combo from Sreamlight to it, but it isn't comfortable to carry with the light because it digs into my leg when appendix carrying.
