Spiderbox 3206 GY6 is burning oil. Swap it? Rebuild it?
thepaultucker
New member here! I'm a great automotive mechanic, but new to the small engine and go-karting world. Pictures just for fun. 👋😊
CONTEXT:
Short version: I found a decent deal on a running, driving Yerf-Dog Spiderbox GX150 (3206). I knew it needed some repairs and love, but I'm up for the challenge, and my kids loooooove it so far.
The Howitt 150cc GY6 sounds pretty good. It's happy overall, very responsive, but it burns oil like crazy. I have to add oil every hour. I'm guessing valve guides, since it sounds so happy and healthy (e.g., I don't think it's piston rings), but I haven't torn it down to see.
QUESTIONS:
1. Any tips on what I should try or look into for the engine oil consumption issue?
2. Should I rebuild the engine or do a Predator engine swap?
3. If I do an engine swap, does anyone have a parts list for their build? I'll happily accept "don't do this..." or "avoid that" advice, as well.
NOTE: I'm not really looking to add power over what it has currently, but I don't want to lose power. It looks like the 212cc would be down on power from what I'm reading? It's pretty good right where it's at right now, performance-wise, for my kids and me to buzz around the property.
Got a photo of the clouds of blue smoke emanating from the tailpipe?
Make sure the engine is not overfull of oil (have to say it) as that can cause smoking.
You might try upping the oil viscosity by a 10 factor (30 to 40) and see what happens. Temporary fix.
Does the kart have a Fwd-N-Reverse gearbox? GY6 usually has that feature.
I think you should upgrade to a 670cc. Better hurry! 😧 😂
thepaultucker
lol... yeah, 670 miiiiight be a tad much for my kid's yard and pasture bombing runs. Looks fun, though! 420 would probably be as big as I'd consider at this stage. 😆
No reverse gearbox on this one. It's just a forward-only with a CVT (rather than a torque converter or clutch), which is common for this model.
It's blue smoke. No photos, but if you can imagine blue smoke, you've seen it. It tends to smoke less at WOT but more at idle and mid-throttle. I'm running 40w now, and it's not overfull. I keep it in the hashes on the dipstick. It'll go from the top to the bottom of the hashes in a couple of hours of driving.
I agree with what he said ☝️.
However, I wonder how Denny’s parts list compares in price to a brand new 301cc or a 420cc Rotaderp? I think it was someone here who reminded us that the common Chinese ATV-buggy-“kart” and the GY6, which we see a lot of, is an over-stressed marriage as the GY6 started out in life as a scooter engine which is a much lighter vehicle...
Here’s an owner’s manual for the hell of it:
Yerf-dog Spiderbox GX-150
thepaultucker
@Denny, I thought about that plan too, but I'm hitting a wall sourcing decent 57mm cylinder bore parts that aren't wildly expensive. 57.4mm parts are everywhere, and it looks like I could mill the case to drop them in, but that's further than I wanted to go. If you know a good source for the 57mm stuff, I'm all ears. I haven't ruled that path out!
Otherwise, by my shopping, I'm looking at roughly $600 either way: a full Predator swap with a 40-series TC and the bracketry, or a new top end on a 20+ year old motor with shrinking parts availability. The Yerf-Dog / Howhit GY6 in my kart is supposedly the "B" variant, and while it's close to the standard GY6 clones, the cylinder and head aren't interchangeable. I assumed parts would be a breeze when I bought it. Not so much.
@Hellion, your point about the GY6 being an overstressed scooter engine in a kart application is part of what's pushing me toward the swap side. Anyone here done the Predator 420 or 301 swap on a Spiderbox and have a parts list or "wish I'd known" notes to share?
I searched the forum for “Spiderbox” and right off hand, I was unaware (or forgot) Eztrail’s project was based on a Yerf-dog Spiderbox.
The engine bay is based on and built around a GY6 so it looks like a crossmember or two needs to be cut...
My thoughts.
That engine sounds wore out. Either top end it and run. Or buy new gy6 style engine. Ive seen 250cc out there. It will be a more "bolt in" fit than converting to an industrial engine.
If your a little fab minded then a 420cc and a 40 series would do perfectly. I have a built 301 and its a blast but I think the 420 has a better aftermarket.
I wonder if Paul Tucker is fab minded? This is DIYGK but both options are totally DIY and welcomed, no pressure for one engine or the other... :thumbsup:
thepaultucker
I'm a master booger welder, @Hellion 😆
Jokes aside, I can weld and am pretty creative, but more talented with a wrench than with a rod. Cutting up the rear end and putting in some plates and cross members doesn't scare me.
Small update: I was poking around the engine last night and realized I couldn't find the end of the vent hose that runs from the head to the air cleaner and into the atmosphere. Lo and behold, the previous owner had CAPPED it and tucked away the air cleaner-to-atmosphere side of the hose. Unbelievable.
Basically, they created a terrible, 1oz catch can that was filled with oil, condensed moisture, and fuel - putting pressure back into the cylinder head. I pulled the cap, drained it, rerouted it to the correct position, made sure it and the head vent tube were both clear, and, wouldn't you know it, the smoke decreased by about 75%.
Anywho, I've still got a bit of blow-by, either at the rings, valve seats, or valve guides (or all the above), but it's a massive difference. Crazy, crazy stuff. Who does that?!? Maybe they saw it drip out a drop or two of oily residue and thought the line had popped off somewhere, so they just capped it? Again, crazy logic.
Anywho.
Looks like I might be able to rebuild the top end from parts at BMI. Upon digging a bit further, it looks like they have 95% of what I need if I decide to go that route.
If it has not been run much since the breather fix, run it a little while longer. You may have to burn excess oil out of the muffler and it may take a while.
Previous-owner Fix ‘em up Bubba strikes again!
In the meantime Paul, with that style of seat you can easily add a 5 point racing harness so if the kart rolls over, you and your offspring units will still be in the seats and not tossed out. You don’t want the Yerf-Dog to turn into a Yeet-Dog. 😂
thepaultucker
