I need to fix the petals on my go kart
cap
I'm trying to find out what kind of pedals these are and what are attached to them. It is from a bks go-fer
cap
Ya do you know where I can get some replacements cus one of the rods are broke the i don't have any of the other things
gokartdave
Lake Orion, Michigan
You'd probably have to buy the rod. I believe it's 1/4" it's threaded at the far end opposite of pedal. I'd have to check on mine to measure how long the threaded end needs to be. Pedals look good.
cap
I was doing some research and it looks like I can use some go power sports pedals and use some cables but if you could still get those measurements that would be great. Thanks!!
Do you know where to buy replacements or if I can replace this with cables
https://www.bmikarts.com/14-Brake-Throttle-Rod-_p_1823.html
Took me all of 5 seconds to find that. I'm not saying this is *the one* to buy, only that it exists as a product. They go have a crazy list of size options there and I have bought from BMI before so they are good to go.
Otherwise I know that 1/4" diameter steel rods can be bought from hardware stores and you can thread them yourself with a threading die, if need be.
Well what do you know, the rear pedals point outwards......
They really needed to agree on the spelling of the kart's name before going to press. :rolleyes:
jclev815
Where did you find this advertisement? Do you have one for the Warthawg?
Scout
Nutjob
Indiana
The rod between the front and rear pedals is in the wrong hole on the front pedal, which is why it is down like it is.
