Governors, Flywheels And An Internet Full Of Crap
Reposting this superb article written by Doc Sprocket, from this thread.
(edited for spelling ~Hellion)
"This has come up recently, again, so I'm going to post this here. What you are about to read is a couple of articles I wrote sometime back, that address the function of the governor, the exploding flywheel MYTH, and all the crap to go with it. What I have written is based on years of personal experience (not "I heard, read, or was told") as well as extensive research and others' personal experience. It was originally written for the go kart crowd, but the same information applies to all similarly-derived small engines. Take it for what it's worth and insert your favourite fine print here, but I'm telling you--there is so much MIS-information out there, it's disgusting. Grab your favourite beverage, smoke 'em if ya got 'em, and read on...
It is absolutely amazing how often we run into this here--and how often we find ourselves banging away on the keyboard, typing out the same old answers. So, I felt it was a good idea to write up a little blurb on the topic. If requested, I'll sticky it to hopefully save us all some future work. Let's start by outlining the governor's job description. Everyone knows that the governor tries to limit engine speed to (usually) 3600 RPM. But wait, there's more. The reality of it is this: the governor's job is to try to MAINTAIN 3600, not just limit it. The governor reacts to changing loads on the engine; decreasing throttle if it starts to run too fast, and INCREASING throttle if it starts to bog. This is why it is called a "governor" and not simply a "rev limiter".
Now: On to the question: "If I take out my governor, is the flywheel gonna go off like an atom bomb, blowing semi-molten schmutz everywhere, and killing every living thing in a 15-block radius?"
The short answer is no. The long answer: There are many factors involved here, and each must be carefully considered.
1.) I always advise people that IF they are going to run well above governed-RPM, to do it by fully removing the governor's internal mechanisms, and NOT simply bypassing it externally. Many governors are designed in such a way that if over-revved, can suffer component interference inside the crankcase, and/or have internal parts forced right off the shaft and bounce around loose inside the crankcase. Either case can cause severe engine damage. NOT an "explosion", just largely screwed-up internals.
2.) IF you are going to run ungoverned with an otherwise stock engine, keep the factory-spec valve springs in place. At a high enough RPM, weaker springs will cause a condition known as "valve float" or "valve flutter". This occurs when the valves cannot slam closed fast enough before the next combustion cycle. This causes compression losses and as a result, prevents the engine from spinning faster at that point. Valve flutter tends to occur in our engines around 5000-5500 RPM. Your results will vary based on your individual engine, spring condition, etc. Valve flutter occurs at a lower RPM than it would normally take to cause a flywheel mishap.
3.) IF you want to get into RPM ranges HIGHER than this (say 5500+), now is the time to go shopping for high-performance internals. A billet aluminum flywheel, connecting rod, and stiffer valve springs are what's called for. Stiffer springs allow the valves to react faster, so at higher RPM, the valves won't float--NOW things really do have the potential to get a little crazy, so it's time to reach into your pockets for better quality parts.
4.) Your connecting rod is MUCH more likely to fail than your flywheel. I have witnessed MANY more conrod failures than flywheel failures. In fact, I have never seen a flywheel failure. Most here haven't.
5). Contrary to popular belief, a flywheel is NOT going to vapourize at 3601 RPM. This is NOT why your engine is governed to 3600 RPM. Your engine is governed to 3600 RPM because it is an industry-standard operating speed for all the implements these engines are designed to power. Let's NOT lose sight of the fact that these are industrial stationary engines, made and marketed with the primary purpose of powering equipment. Generators, pumps, power washers, welders, cement mixers, tillers, trenchers, tampers (you name it) and the implement are designed to run at 3600 RPM, so the engines are factory-set to 3600 RPM. It's that simple. When a flywheel is manufactured, it is designed to run well above normal operating speed. It's called a safety margin.
6.) NOTHING is 100% guaranteed. You can do everything completely properly, and have a flywheel fail at a "normal speed". OR, you can do everything wrong, and run the hell out of the engine at 7500 RPM on a stock flywheel for a lifetime and never have a problem. Sometimes, there's just no accounting for "Sh*t Happens". Write that down.
7). IF you are running an otherwise stock, ungoverned engine, is it advisable to avoid excessively free-revving the engine. Use proper gear ratios to keep a bit of a load on the engine at full speed, wide open throttle. Don't try to rev the crap out of the engine with the clutch, chain, or belt off. A load on the engine helps keep harmful vibrations (harmonics) in check. If you have an insanely long, steep downhill stretch in your riding route, back off the throttle going down it. If you hear the valves floating or the engine starting to over-rev, apply some braking force. Coasting too fast can force the engine to spin even faster than valve flutter can prevent.
8.) Inspect your flywheel before removing your governor. A previously damaged flywheel can break apart at a completely unpredictable speed. Damage may not be visible (sh*t happens) but if it IS visible, replace it.
9.) If you have to remove your flywheel for repair/maintenance, remove it properly. Do NOT beat the hell out of it with a sledgehammer or pry on it, invest in a flywheel puller. Failing that, try the following: Loosen the retaining nut until the nut is flush with the end of the shaft. Now, hit the nut squarely and sharply a few times with a hammer. Most times, this will do it. You can also aid in loosening the flywheel with mutiple taps around the circumference with a soft-faced mallet or deadblow hammer. Do NOT beat on it with a steel hammer.
10.) If you need to hold the engine from turning while you are tightening/loosening a crank bolt or clutch, do NOT wedge a screwdriver or bar in between the flywheel fins. Although this is not likely to crack the flywheel, a fin could break off. This will throw the flywheel's dynamic balance off. An out-of-balance flywheel is just asking for trouble. Same goes for sawing off alternate cooling fins (an old performance trick). If your fins are cast into the flywheel, don't do it. If you have a Honda, clone or other engine with plastic fins, go for it.
11.) Handle with care. Once you have the flywheel off, don't drop it...
So--Armed with the above information, go ahead and make an informed decision. This guide arms you with what you need to know, to decide whether removing your governor is a feasible idea and how to handle things if you do. And remember (for all the "Armageddon-is-coming-prepare-to-meet-thy-maker-in-a-sintered-metal-flywheel-induced-world-war-3-esque-everybody's-gonna-die-including-the-cockroaches-in-the-cupboard"-nervous-nellies out there): Sh*t Happens. On the one hand, your stock flywheel will very likely be fine. On the other hand, even a performance part could fail. Sh*t Happens.
One last point here: For those that may not yet be ready to dive into their engine and come out with a handful of governor parts, some engines (most notably Hondas and clones) have a VERY user-friendly means of governor adjustment. This adjustment is designed to fine-tune the governed speed to a different specification, but makes it super easy to gain a few hundred RPM. You can usually bring your GOVERNED MAX to 4000-4200 RPM with the turn of a screw. Your governor will still do its job, but you'll run a little faster. Locate the manual throttle control on your engine, it's the little lever you would slide to increase or decrease RPM if you didn't have a remote throttle (gas pedal). Behind that lever is a screw with a spring wrapped around it. Notice how the throttle rests against the tip of that screw when you move the lever to the "fastest" position? Great. Remove that screw. Presto--instant maximum RPM increase, no fuss, no muss.
It is also worth noting that these engines were designed to run at 3600 RPM, day in and day out. If you do run faster, the engine will wear faster. Fact of life. Treat it well, maintain it well, and you'll never notice the potentially shorter lifespan.
(continued)
Governed Idle FYI
The governor is a seriously misunderstood engine control system. For the greater good, here's a little FYI, an experience I just had. Might benefit someone in the future.
Where were we? Ahh, yes- the governor. Contrary to popular (mis)belief, the governor does much more than limit engine speed to 3600 RPM. Wonder why it's not called a "rev limiter"? There's more...
The governor's purpose in life is not so much to limit RPM, but SET it. What's the difference, you ask? (I swear I just heard one of you ask that!) The difference is this: SETTING an RPM means KEEPING that RPM throughout the workload. Let's use a lawnmower for example. You start the engine on your walkway and run the throttle up to max. The governor sets the engine to 3600 RPM, and there is no load (it is not cutting grass). As you move into the grass, the engine starts encountering a load and slows down a bit. The governor allows a throttle increase to bring the revs back up to 3600. As you're cutting away, you encounter a thick patch over the septic tank. As the engine begins to bog and the revs start to drop, the governor allows the throttle to open more and bring the revs back up to 3600. Cool? Great. Going around the corner through that thick grass with the throttle wide open, you hit that bare spot where the dog keeps peeing. The load comes off the engine, and as it begins to increase, the governor closes the throttle to prevent over-revving and holds it at 3600 RPM. Got it?
If you examine your external throttle linkage, you will notice that there is no direct connection between the hand throttle control and the carb butterfly. It's the governor. The hand throttle does nothing more than alter the spring tension between the governor arm and the throttle butterfly. Setting the manual control to "Idle" merely alters the spring tension from the governor enough to allow it to SET engine idle speed. The idle adjust screw is the bottom end rev limiter in that it sets the baseline that the governor drops to. I told you that to tell you this:
I recently had a situation that some folks might misdiagnose: an engine that refused to idle properly. After a barrage of time, abuse, and adjustments, the Chinese Kohler-clone on my kids' kart would not sit at idle. The kart constantly wanted to take off with no throttle input. At a glance, the idle was too high.
Close examination revealed that the idle stop screw on the carb was not doing anything; the butterfly just would not rest against it. If I pushed the lever by hand, it would sit at idle RPM, but as soon as I let go, it would take off again.
I tried to adjust the external governor components to no avail. With the arm off the shaft, something just did not feel right inside the engine. I pulled the engine off the kart and tore it down. I don't even know how to describe what had happened inside, but the governor guts were all over the place, literally.
By some miracle, nothing was really damaged. Short version of the story? I epoxied the "press-fit" governor gear shaft back into the side cover and reassembled everything. I (re-)adjusted the external components, and wouldn't you know it? It idles like it just came out of the shipping container at 1310 RPM, and maxing at 4230 as measured by my optical tach."
Food for thought.
Years ago that was the standard answer to the questions. Then some knowitalls joined the board and convinced everyone that they needed rods, flywheels and cams to rev more than 3600. It became easier just not to fight with them because the unwashed masses hung on their every word. No matter what proof you showed them. The bling always wins.
Cant thank you enough. Ive been on the fence about removing the GOV before actually getting all hardened/billet parts.
Youre right. All the fly wheel crap out there made me put it off. The thing that really got me was one youtuber saying it, "dont remove or adjust the GOV without upgrading your internals. Youll blow up your flywheel". Pretty popular Youtuber but I dont wanna name names. -But then he starts talking about the weed all over his scale that hes about to use to measure primary drive clutch weights with... Lol
Good to know Ill *probably* be safe... Good enough. Eh, this engine has been factory sealed for long enough...
I post here some semblance of the real story about the exploding flywheel that caused a death or injury. It's anecdotal but probably been told in some variation 100+ times on that forum and elsewhere, but why can't we know the names and the date? I understand bereavement and privacy but it's probably been 30+ years ago now and knowing the names would humanize it beyond the cold facts and give it more of an emotional impact. Take it for what it's worth, but I hold Brian Carlson of Carlson Motorsports in pretty high regard in that he's not just trying to sell billet flywheels.
It is not stated implicitly but I think the Briggs 5 horse in question was most likely turning in the 10,001 RPM range when it went.
https://4cycle.com/karting/threads/safe-flywheel-for-5hp-briggs-flathead.87731/
Also, was Doc Sprocket a member here at one time...? I know the name but I cannot find him via search nor can I find the member list showing all 42,653 members (that number can't be right!)...
Yeah Doc was a moderator on here. He's now an admin over at the All Terrain Lawn Tractor forum. Not sure if he's still active over there or not. He hasn't post much on YouTube in months, maybe a year or more at this point. Busy with life I suppose. His last project on here was the Diesel Weasel that he also did on the tractor forum.
His YouTube channel is Sprocket's Garage.
Sparkwizard
Richlands ,NC USA
I am an old member of the "billet or leave the governor alone" crowd, simply because of the unknown quality controls in the cheap clone engines. I have seen MANY tecumseh rods let go. That only made noise and the inconvenience of pushing you bike or kart back home. I never saw a flathead flywheel come apart. I have seen about 6 early clone OHV flywheels come apart. Only two of those were able to break through the blower housing and only the one on a minibike made contact with the rider. In that case, back in about 1995, the rider lost his right leg, bled out and died.
I know this was a really extreme case where the engine was extremely abused and the incident was in a really remote location, but it was really brutal and I try to advise people to avoid overspinning small engines and allowing children to ride them.
Adults, do what you feel comfortable with, but please protect the innocent folks in your care.
I think it's mostly Old Mini Bikes forum and members that push the billet flywheel and connecting rod with Governor deletes. Think the joke is that they will ban you if you post and do otherwise.
That happened in the last year with minibuggy.net. The owner of the site, actually the second owner was no longer able to keep up with the cost of running it and updating it to Vbulletin 5 or whatever. The person that runs the Facebook group for minibuggy.net was supposedly going to take over the forum. We'll something fell through and the website no longer exists. That had a lot of useful information that barely exists anymore. A couple pages were saved to the Wayback machine and archive, but only a few build thread pages exist and you can't just go to the next page for those.
Robert, the owner/admin of here hasn't been on here in a hot minute. But everything still works here. Mods have some cleaning up to do because new members tend to start threads in areas that are the wrong category.
4 karts and 1 bike. Every one of the engines is built. The usual stuff, no gov, carb,
header pipe, springs, cam, rod, and flywheel. Some quite a bit hotter. Milled and
professionally ported head, Gage roller rockers, longer rod flat top piston. As hot as I can make them. No tach on any of them. Don't know how high they rev. My grandkids are the ones who use them. I most certainly don't feel like I have spent money unessassarly on fly wheels and rods ( two of the most expensive aftermarket hop up parts). I won't build an engine without them. I'm probably one of the oldest ones on here, but your thought process changes the older you get.
So many of the new threads on here start " Hi, just picked up a kart for my son, or I am fixing up a kart with my Grandkids ". If you are a teenager or young adult and building it for yourself, do as you please. BUT if the hopped up engine is going on something to be used by your children or grandchildren I feel quite strongly against the earlier post on this thread that make it sound like you are some kind of sucker, or throwing your money away by buying these two parts. Somebody in the room has to be the adult when young ones are involved.
Jimmyjoe
(continued)
Governed Idle FYI
The governor's purpose in life is not so much to limit RPM, but SET it. What's the difference, you ask? (I swear I just heard one of you ask that!) The difference is this: SETTING an RPM means KEEPING that RPM throughout the workload. Let's use a lawnmower for example. You start the engine on your walkway and run the throttle up to max. The governor sets the engine to 3600 RPM, and there is no load (it is not cutting grass). As you move into the grass, the engine starts encountering a load and slows down a bit. The governor allows a throttle increase to bring the revs back up to 3600. A you're cutting away, you encounter a thick patch over the septic tank. As the engine begins to bog and the revs start to drop, the governor allows the throttle to open more and bring the revs back up to 3600. Cool? Great. Going around the corner through that thick grass with the throttle wide open, you hit that bare spot where the dog keeps peeing. The load comes off the engine, and as it begins to increase, the governor closes the throttle to prevent over-revving and holds at 3600 RPM. Got it?
Food for thought.
Thank you for the info. Will put it to use .
John Roger
Tucson Arizona
I never truly understood the flywheel situation i know the magnet would always go first because its held on by glue and a screw but thats still pretty strong glue as like karl said 6k-7k it goes and I've seen it happen on a predator 212 (in a video never in person) but I was always scared to remove the gov internally i though my engine would explode but i was wrong i bough some safety stuff like flywheel and well thats it my engine still wont run above like 5-6k but still just want to be safe but I did not know the rod would fail first I learn something new on this forum every day what about the bigger engines like predator 420-459 or even the 670? also I did not know you could adjust the governor (how do you do that) and I did not know the governor worked like that I thought it was more like a rev limiter but I guess I was misinformed
