I break em on a test stand. Usally they stay on there for 3 or 4 days.
I turn the idle up above 2500 rpm, and run up and down throttle from 2500 to 4500 the first 15- 20 mins. This allows the cam and lifters to break in together. I've ruined a bunch of cams and lifters in the past. I havnt lost a cam lobe in a while doing it this way.
After that up and down, 15-20 mins, I set it to run at 3000 rpm steady for 5 mins, then turn it to 3500 for another 5 mins, then up it to 4000 for 5 mins, then 4500 for another 5.
Then I start turning it back down to 4000 for 5, 3500 for 5. Do this till I get back down to 2500 for 5 mins.
What I'm doing here is building different heat in the engine and getting the rings to seat to the cylinder. Keeping an eye on the temp with a gauge or infrared temp gun.
Sometimes, I have to cover some of the blower air inlet holes to get the heat up. Depends on the outside weather.
After all that, I drain the oil while its still hot, refill it. And let the engine set over night.
The next day, I go around a check bolt torque spec.
Start with the flywheel nut, then the side cover bolts, then the head bolts, then I check valve lash.
There ALWAYS will be 1 or more bolts not in spec, and valve lash always needs adjusted again. This is the bolts stretching and contracting during the hot and cold cycles.
Valve lash is from the valve train parts wearing in together. ALL NEW ENGINES WILL LOOSE LASH DURING BREAKIN.
After that, I start it back up and run steady at 2500 for 5, 3000 for 5, ect, ect, ect, til I get back up to 4500, then start turning it back down til I get back to 2500 again.
I don't have to do the up and down throttle for 15-20 mins anymore, because the cam and lifters are already broke in.
Again, watching temps as I raise and lower rpm.
Drain the oil again, refill again and let it sit over night again.
I keep doing this until the bolts stay torqued and the valve lash dont have to be adjusted any more.
This way works and I never have to check bolt torque or valve lash again.
My son's engine has over 300 hrs on it, never have I done any thing to it except oil changes, air and fuel filter changes. Same spark plug I put in it over 15 months ago.
Mine, I'd say around 120-150 hrs, and have not done any thing, not even a spark plug change. Jus oil, air and fuel filter change.
I don't like problems on the trails, so I spend alot of time on the test stand, checking, tuning, torqueing.
It works for me.
You could always throw it on and run it,
like 90% of MOST do
