student👍
Hi
I don't know much about working on a go-kart and I'm pretty new at it. I also don't have any budget at all, I can only do free mods to my kart. except for essential stuff like oil and gas( and the occasional broken part), I have a love/hate relationship with the kart since every time I fix something something else breaks or stops working, I learn about engines as I fix it so it always takes me a long time to find the problem. I have a vintage-style go-kart with an Ironton 208cc horizontal shaft OHV engine, I got this kart secondhand from someone who said it ran and did a solid 40, When I got home and tried it it didn't run and after some carb cleaning and new oil I got it to work and it did 30ish (somewhere round there), over time I've done free mods on it like bypassing the governor( I didn't remove it I only did the zipline trick ), I am still trying to tune the afr (after 2 years), I put a predator carb on it and now it ACTUALLY does 40. Ever since I zip-tied the governor it's (obviously) been revving way higher, however, I have two problems with it now, 1. The afr was good for a while but ever since I ziped the governor it's been shutting off when idling after going at full speed so I guessss its the afr and 2. Like I said before I ziped the governor BUT like I also said before I only get money for essential parts, and stiffer springs to make the go-kart faster slash more dangerous is not something essential so I think I've been getting valve float or something like that because there is something SERIOUSLY wrong with the exhaust valve, every time the intake valve closes the exhaust opens a little bit, like 2 or 3 ml, idk if this is normal or not so I really need help with that.
first time in a forum dont rlly knw how it works.
