EagleTalons
Master JB Welder
Why would you even pay for a lightened flywheel then..?
So the question is: is a lawn mower engine have a heavy enough fly wheel without a blade to maintain through the power stroke/ stabilize drive shafts? Where is the payoff of a lighter flywheel more torque off the line?
The payoff is above the 4k-5k mark and above.
A combination of the above...OR...he is smart enough to know that he has to yank with some fortitude.He didn't seem to have any trouble pull-starting it either, a topic that has come up with regards to vertical engine conversion (flywheel). Could that be because the compression is weak on that engine, or is it that the flywheel is heftier that some other verticals?
Hey sideways did yours work? i cant find your thread
All well and good...
Let's see it mount/work on a kart.
Anyone?
Anyone at all?
keeps on breaking pull starters
also after you get driving the momentum of the kart will take the engine through its compression stroke
couldn't you rope start it?
How about a vertical from a pressure washer? Those probably have heavier flywheels right? Or am I missing something else in the pressure washer that acts like a flywheel?
