https://www.amazon.com/gp/product/B078XCL153/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
WPHMOTO 48V DC 1800W High Speed Brushless Electric Motor & Controller & Wiring Harness & Forward Reverse Switch For e-Bike ATV Go Kart Moped Mini Bikes Motorized Bicycle by WPHMOTO
• Motor: Rated voltage: 48V DC, Output: 1800W, Rated speed: 4500 RPM, Sprocket:T8F 9T, Peak efficiency: 80%
• Controller: Rated voltage: 48V DC, Current limit : 32A, Conversion efficency: 95%
• Advantages over traditional brushed motor: high efficiency, power frugal, low noise, Long lifespan, stable.
• Suitable for go karts, scooters, e-bike, atv, motorized bicycle, moped, mini bikes, pocket bikes and electric dirt bikes
• Package include: 1 x motor + 1 x controller + 1 x wire loom + 1 x forward reverse switch + 1 x Accelerator Pedal
I have replaced driver sprocket with a 11 Tooth 10mm Double D-Bore Sprocket for #40, #41, and #420 Chain
I have a Live Axle Sprocket 60T
I have a 3 foot - #420 Style Chain
I used Kart Fab’s “Deluxe” Two Seater Plans – lots of steel
I have 145 x 70-6 V Tread Tires and 6" Live Axle Wheels, 1" Bore
I have 4 12v 35 amp hour AGM batteries
I have rewired as noted above for Left Hand side sprocket (Hall Sensor and Phase Wires)
Technical Details
Manufacturer, Brand WPHMOTO
Manufacturer Part Number WPH-TD010-2+WPHTD037+TD057+TD050+TD056-1
Additional Information ASIN B07PWQ6Y94
Date First Available December 25, 2017
Product Warranty: For warranty information about this product, please click here
Wiring:
Battery: Thick Black (Power Negative) /Thick Red (Power Positive)
Motor: Thick Yellow (Motor Negative) /Thick Blue (Motor Positive)
Ignition Switch: Thin Red (VCC)/Thin Blue
Indicator: Thin red (Indicator power output) /thin black (indicator negative)
Brake: thin yellow (Brake signal)/thin black(Negative Power)
Speed governor: Thin blue (Speed handlebar Signal input) /Thin black (Negtive Power) /thin red(5V Positive Power)
Charge Port: Thin red (charge input power Positive) /thin black (Power negative)
Brake Light: Thin red (power Positive) /thin black (Power negative)
The controller has 4 groups neccessary cables: Battery, Motor, Ignition lock, Derailleur (throttle), when hook up these 4 groups cables, the E-bike can run normally. Besides, this controller has other optional functions, you can hook them up according to your applications.
THANKS so much...Barry
