Ok...could use some advice. Don't recall ever having a go-cart, but a friend asked me to help get this running for him. I normally work on cars/trucks/tractors...and stay away from small engines!! But will help out where I can.
I have no idea of what kind of cart this is. But it does have a Tecumseh 5hp 0HH50 engine on it.
All I know is that it doesn't run! All the detail I was given.
The pull cord was gone, so I put a new one on today. I still need to shorten it a bit. The fuel looked and smelled fresh. (Haven't ruled out having to drain the whole deal and clean the carb). The plug looks new, clean, and dry. But pulling the cord, it turns over but no indication of trying to fire.
Anyone know of any typical issues with a cart like this? I can't find my spark tester, so I need to get a new in-line tester, but is there anything that I should service along the ways of ignition?
And there are two prongs on the engine (last pic) straight below the carb bowl. Any idea on what they are for?
.....YES!!!!!!! ........removing a shroud requires EXTREME CAUTION........you never know what might be living in there!!!!!!
