Clutch Adapter
Desertduler
Here are some adapters that I have made to adapt one inch bore clutches to 30mm 1-10mm tapered snowmobile crankshafts.
I have used Noram and Comet clutches and they have held up very well under punishment,I am just showing a couple of these just to let others know that you can buy a small donor snowmobile engine real cheap and adapt a clutch to them and install the engine on a kart and they rip! My favorite small snowmobile engine I use is a 277 Rotax out of a Ski Doo,I have two of them and they work very well.
Desertduler
Here is how I cut the keyways.This one is made out of chromoly, I am going to use it on a special engine configuration.
firemanjim
Just kartin' around....
Houston Texas
I know a couple guys on here that might want to pm you. I have yet to have time to make some adapters for them..... There IS a market for these things....
Desertduler
Ok, I am up for helping out fellow karters that want to have the thrill of feeling the power of twenty plus HP and not worry about a flywheel explosion or valve float or oil starvation of a splash system etc, and want to run 7000 to 8000+ rpm all day long inexpensively.
I will leave my compound set up on my lathe and my milling vice set up on my mill for cutting keyways in one inch shafts,I would suggest using Noram Enforcer Clutches so in fact if there is a need I will indeed be willing to help out but only if someone is serious.
Bret :thumbsup:
Desertduler
you think this clutch will hold up well if i asked you kindly to make me a adapter.:) I need one for a 1'' shaft down to 3/4 shaft. it will be going on a 13hp 346 predator engine and maybe a jackshaft setup to. also how much will you be Chargeing for a adapter? http://www.mfgsupply.com/gomini/gominiclutch/gominiclutchrace/gominiclutchracebrister/4-7680.html
I would not advise doing something like that or would I make something that could possibly hurt or kill you. With the torque that large of a engine creates you would be flirting possibly with a dangerous situation.I would save your money and buy the correct clutch.Getting hurt or killed would not be cool.3/4 shafts have their limits and you would be exceeding them.
The type I make are a tapered swedged fit and they do not come loose a straight keyed shaft adapter would in time come loose and fail.
Sorry.
Desertduler
Here are a couple of pictures of my chromoly clutch adapter installed on my ''Super 277'' Rotax with a Noram Enforcer clutch installed on the adapter.This engine has been ported by me and I have set up the squish band clearence at .050 and I will be using a 36mm Mikuni Carburetor on the engine along with a expansion chamber that I will make with the aid of software that I have that designs the tuned pipe according to the engines port timing and port configuation.I have tried a my stock 277 on my kart with just the original snowmobile exhaust and a 34mm Mikuni on the engine and it flat out moved!So we will see what this one will do compared to the stocker.
machinist@large
West Michigan, 49331
Do you have any issues with the overhang that the adapter needs? Excessive side loading on the bearings, harmonics/ vibration/ runout? My machine building background generally states that you want as short an overhang as possible, so I'm curious about your in the field experience...
Pat :thumbsup: :cheers2: :popcorn:
Desertduler
That is as short as I can make them.You are correct on the overhang being a little long I have ran these adapters close to 9000 rpm's and they have not failed my KM24 wankel has one on it and I have over 27hrs on it with no failures so far.I have ran one on my other 277 Rotax and my 303 wankel with no problems at all and the 277 has a little vibration to it because it is a recipocating engine and I am not easy on any of these different set ups I had close to 40hrs on my 303 and the hour meter I was using on that engine quit working and I kept running it so I do not know how many hours that engine has with its clutch adapter I have radiused and polished the adapters inside and out with the hope of not having one crack and let go but so far they have all held up and all the engines output shaft bearings are good I have kept an eye on them just to see if they started to show any signs of play.The 277s will need more time on them to tell for sure how they will do because they will induce more vibrations than the wankels do.My 528 OMC has very little time on it I installed it and tried it out and I removed it for modification but I have a different set up on that engine.If I had any runout I would not even think of running them.
Desertduler
How well will this hold up on a 440 sled motor
I would not put one on a engine with that much power and I think the clutch would not take it either.
At first I was going to turn the output shafts of the engines down to size and cut keyways in them but if the shafts twisted off I would have had a hard time finding replacements for the wankels so I went this route and so far so good, but I need more testing time on the piston engines to verify the durability of them with the modifications I have done to the engines.
Armilite
Ames, IA
Rotax 277
Hello:
Have you ever made a Flywheel Adapter for the older Rotax 277 Cranks with Bosch Points, the Mag End, to use the bigger 377-617 CDI Flywheels?
I'm told Flywheel #995-110 fits the smaller taper cranks, but I haven't been able to find one. Been looking for 6 months. I want CDI Ignition. I want to run a dual plug head for a Big Bore project. Later 277s used the bigger Taper, but I don't know when the made the change over.
Do you know anyone who makes 277 66mm Stroke Cranks today?
Any 70mm Stroker Cranks available?
My 1981 Skidoo/Rotax 277F Crank Mag End Taper is 23.65mm (0.931") on the Big End, 20.96mm (0.825") on the Small End, 23.59mm (0.928") Long.
The Bigger Mag End Taper on say a 377 - 617 is:
27.8mm (1.101") on the Big End, 24.6mm (0.968") on the Small End, 23.8mm (0.937") Long
My Dual Plug, unfinished head, is a AERMACCCHI motor cycle head. The finished head, is milled for 14.5cr used on a stock bore 277, run on Race Fuel, with mild porting, a Tweaked 670 Pipe, by a guy over seas, on a old sled, turnes it 9200rpms Drag Racing, he est. 55-60hp by his race times.
Rich
Desertduler
Hello:
Rich
Hi,
I have not made an adapter like the one you are asking about but anybody with a lathe and a brain should be able to do so and then you would also have to make a custom woodruff key to phase the assembly together which would not be a big deal.
As for your crankshaft questions I do not know of any new ones being made right now I have a spare 66 mm stroke crank that I am waiting for a connecting rod assembly for and they are due to be released around December of this year.
Are you going to use a cageless wrist pin bearing set up on your engine? I would suggest that you do because the the small end of the connecting rod will last a lot longer than a caged wrist pin bearing does.
The cylinder head that you are going to use has the combustion chamber dome in the center of the bore the stock cylinder head for the 277 has the dome farther off center away from the exhaust port to keep the crown of the piston near the exhaust cooler because of the exit of the exhaust gases tends to heat up the piston crown in that area and swell the piston on the exhaust side this is done to help keep the piston from swelling and seizing of the engine just a thought.
Armilite
Ames, IA
Adapter
Hi,
I have recently found out, you can use the original Points Flywheel, either rekeyed at 10 o'clock for the Nippon CDI, or pinned at that position with a roll pin, and then use a 80's Horse Shoe Type CDI Stator setup, and CDI Box, and a Single wire CDI Coil, or in my case a Dual Firing 377 coil, to fire dual plugs. Yes, I'm going to use Cageless Bearings on top, and Ceramic Crank Bearings. Skidoo/Rotax, made many different Heads for the Singles, with the Plugs at different angles. The 277 use's the highest 11.8cr of them all. I'm also using Ceramic Coatings on Piston Top, Combustion Chmaber, Exhaust Port, Pipe. Ceramic Coatings reduce Temps by 20%. I'm also going to run 100LL which runs cooler. I'm doing a Big Bore, thinking 82mm, probably use a Seadoo 720 Rod & Piston. I'm also going to run 40:1 Oil.
Rich
Armilite
Ames, IA
What is the two Mag End Tapers for the 277 called?
Rich
Desertduler
Rich
The next time I have the flywheels off of my 277's I will give you their size and tapers.I have both points and CDI cranks.
None for sale.
sparky87213
How long did you make your clutch adapter? I'm planing on putting a Arctic Cat 275 twin in the go kart im racing and you literally saved me months of figuring and brain storming lol.
Armilite
Ames, IA
What you need to convert a Rotax Points Engine, and works on others to convert to Nippon CDI. You use the Bosch Points flywheel which is keyed at 12 o'clock, and either rekey/pin it at 10 o'clock.
Item Rotax # Aftermarket
1) CDI box Rotax 420-866-595 Kimpex 01-299
2) stator gen coil 420-866-635 Marshall 11-1347
3) external ign coil 420-866-660 Mfg supply 01-113
4) roll pin NA 5/32 roll pin
Rich
