54inches
Vagitarian
I have one concern, you welded the roll cage to a frame that was designed to flex, this is why thay bolt them on. you may have some trouble keeping the welds all in intact, being that the frame is going to flex some and this kart is a light frame with no kind of suspension to take away the stess that this frame is going to be under while it's being redin. I don't see that it will hold up long unless it's ran on smooth, flat ground. I have one similar to the one you have there, just running it around the yard the frame will twist some on mine.
I would be concerned with any other frame, but this Kartco is not light by any stretch of the imagination.
I don't think these frames/cage were "designed to flex. If they were then they were not designed well as I found and repaired one crack.
The ere bolted on for safety reasons and ease of shipping/packaging.
I also added 4 more down tubes to help with triangulation and energy spread.....
If it does crack, then I will gusset it where it needs it; which was my intent in the beginning, but I forgot to make the gussets.
This will be street/concrete Kart and ridden on mostly flat roads.
Just to convince myself I am going to do a full speed canyon jump to test my welds!
Thanks for your input, now I am paranoid.
