First kart project.
Gopedude
Keller, Texas
If I were you, I would put plywood gussets on both sides of each corner and joint, like in this picture.
As for the axle, do I recall that you are planning a single drive wheel? If that is the case, you can get a pair of cold rolled steel rods that are the same size as your current axle. Then you can make a box like the one in the picture below to mount your new axles in. You should be able to pull it off without welding anything. I am not going to suggest anything that requires welding, but keep in mind that you need to make sure that you 1) keep the speed way down, and 2) check your bolts before every ride.
I picked up some 90 degree metal supports. Should help.
So, that box holds the spindle? Link?
  • 5F97A5AD-46F1-46C5-9FE4-1546AE87D25D-10576-00000073D2AC2BB0_zpsf9435865.jpg
36" Wide? Wow... That's a whale! Most classic style karts are well under half that wide. There's going to be a lot of torsional stress on that.
DaiSan76
Nixa, MO
I was actually imagining that you would make one out of a couple of chunks of 4" x 4" square steel tubing and a hole saw. If you are willing to knock on doors you should be able to find a shop with a scrap bin that will let you have/buy a couple pieces of their scrap.
Really? I thought 3ft was small. How small can i go and still fit two people?
Think thin!
With everything else that has gone on, I missed the fact that you want a 2-seater. If this is indeed the case, you MUST seriously extend the track width. That's gonna be tippy as all he// with the current configuration. Get the wheels OUTSIDE the frame rails!
Not those ones. To be effective, you need brackets about 4 times that size. Better to go with daisan's plywood option...
In fact, if you cover the rear of the frame with a single piece of ply (between the two rear rails) you have the makings of an engine mount
traxxaskid
RI
Is this a joke??? I'm speechless! So far I see a chunk of a hand truck, crappy pine littered with holes, the thought of 2 people!?! So you don't just want to kill yourself you wanna take someone else with you! Ughh words can't describe..... Anyway I think you'd be better off with the refrigerator box!
Dude, we've ALL been there & moved on; please follow suit...
Gopedude
Keller, Texas
Ill look into it.
Gopedude
Keller, Texas
Think thin!
Im either going to make the width of the frame the width of the tracks, or im going to find a whole new wheel system.
Gopedude
Keller, Texas
Dang. I was thinking those metal mounts would help
I plan on using the actual wagon which is a piece of steel to mount the engine on.
Gopedude
Keller, Texas
Is this a joke???
Nope. This is for reals.
I'm speechless!
Awesome!
The heck is a hand truck?
We actually dont know what kind of wood it is.
Its not a thought anymore.
Jesus has helped me out of that depression. So no
Its a pretty simple design. You play with rc trucks. Those are pretty complex.
crap. Threw it out last week. Bummer
In all this forget the wagon. Get a piece of 1/4" even 3/16" plate just an inch or so bigger than the footprint of the motor(I dont remember what the footprint was off hand) and use that. mount that to what ever you contraption is going to be.
The wagon's sheet metal is going to move and eventually warp from the vibration and torque.
Gopedude
Keller, Texas
when i get to the engine process ill do this. So should i go to a junkyard to get some scrap metal?
Junk, scrap, metal yard, somebodies metal fab shop, where ever. Try to ask some small local shop before going after the bigger places. most places wont deal with you unless you are a bit persistent but not rude. It also helps to have some drink(in your case non alcohol) like pop or water to ease the bartering. when people see that, sometimes they are more willing to help you out.
Who knows, hand a few drinks out and they might let you take what you can carry. so have a bit of a plan involved. You might get the jackpot coming to scrap.
Gopedude
Keller, Texas
the art of bartering :cheers2:
My dad knows a guy who works on cars and welds, so he might have some scrap. If hes willing, and has enough scrap, i might be able to get him to weld me a frame. Not likely, but possible. For now, im going through with herbie.
