Gopedude
Hey guys.
I am new to karting, but not new to motors.
Ever since i was little iv'e wanted to build a gokart. I got a Goped (gas powered scooter) a while back and decided i wanted to build something with four wheels. My goped has a two stroke which i learned how each and every part worked and how it went together from fixing it so much. Anyways, my friend had this old lawnmower sitting around and was wanting to throw it out. Instead he gave it to me, and after cleaning it out good it started right up! Even though its a four stroke, im sure i will learn my way around it real quick. So since receiving that motor i decided to finally fulfill my dreams (or my boredness) my making a kart. I will be making it from scrap and anything that i can build instead of buy, i will build.
With that said, i have no welding skills, so a metal frame was out of the question. I went ahead and decided to use 2X4s for the frame and motor mount ect. Yes i know it wont be the strongest, but its my only option with the money i have. I started the frame today and will continue with the steering setup in a couple days.
I plan on making it a two seater, even though the frame is roughly 3 feet wide by 5 feet long. Luckily im skinny though hahaha. So back to the steering, i am planning on using the standard gokart steering mechanism with the two poles. (i have no idea what its called) Rack and pinion is the name possibly? i plan on making the steering out of mostly wood, but would be open to buying some sort of kit online. I am trying to spend less than $60 altogether if possible.
I would like to hear what you guys think and suggest.
heres some pics:
This is the frame currently
http://i1284.photobucket.com/albums...CF2A49-11236-0000007ED5214507_zpsd59e5e15.jpg
This is the motor. It is a Briggs and stratts and is rated at 4hp. should be plenty of power.
*quick note here: I realize that this is a vertical shaft motor and i need a horizontal shaft motor. I will be doing the conversion to it with the oil slinger and everything. I will probably ask several questions of this thread.
http://i1284.photobucket.com/albums...994310-11236-0000007F071C0F74_zps8e0d5ace.jpg
Hopefully the pics work
heres some pics:
