Adding electric start to pull type motor
JonathanEngr
Bostic, NC, USA
Hi, all! I'm new here to the forums.
My children are 7 and 9 years old, and the electric riding toys of old are getting entirely too small. Thus--time to look into a go kart :)
Although I ultimately plan to convert a gas go kart into an electric one, I want something functional for them immediately. Craig's list is full of 2-seater go karts with active suspensions, which keeps me from having to build the frame.
Anyway, the go kart I'm currently looking at has a "Homelite" 196 cc engine (the model number may be coming soon). It has a pull start motor, but I would like to convert that to an electric start if possible.
Does anyone know if this is possible with this engine? I've read online that some pull start engines cannot be converted to electric start (at least without extensive modification). Is this true? If so, does anyone know if this engine can be converted to electric start?
Thanks in advance for any help!!
EDIT: Just got this in... this is the information shown on the engine:
CHONGQING HENSIM GROUP, 6CHGS.1961CH, HOMELITE 196CC, OHV
Hi- Welcome to the forum-
Your engine falls into the class we refer to as "clones". Anything that is a chinese knockoff of a Honda GX series engine is called a clone, although some are truer copies than others. As a general statement, all parts from the real Honda GX counterpart are interchangeable. In your case, Honda GX200, 6.5hp. This should help your research.
That said, I'm not sure if Honda ever produced an electric start GX200, but I HAVE seen kits on Ebay to convert them to electric start using OEM and/or aftermarket parts. Start your search there.
JonathanEngr
Bostic, NC, USA
Thank you for the information! I've already found a few "kits" and have inquired about their compatibility. Hopefully I can get a definitive answer from someone.
JonathanEngr
Bostic, NC, USA
Okay--what about a tecumseh 6.5 HP engine? Better shot with that one? I hate to ask about another engine, but I can't seem to find a definitive answer online.
JonathanEngr
Bostic, NC, USA
Never mind... I called several small engine shops and they warned me off of the Tecumseh engines. Supposedly they aren't very good engines, and since Tecumseh went out of business several years ago parts are very difficult to come by.
Looks like I'll be going with the Honda clone! Thanks for everyone's input.
Parts may be a bit more difficult to find, but the engines are not as bad as some people would suggest. In fact, if we were talking about the H-series L-heads, I'll put them up against nearly anything!
jamyers
Buffalo Gap, TX
Homelite 196cc is a Honda clone. Ebay has electric starter kits (starter motor and ring gear) for just under $100, but they don't include the charging coil that goes inside the flywheel - so you'd have to plug it into a charger when you're not riding.
I'm thinking of adding an electric start to my Predator clone, but instead of the above route, I'm looking for a deal on one of the old Delco combined Starter/Generators - hook it up via a belt/pulley drive, and it starts the engine, then charges the battery.
JonathanEngr
Bostic, NC, USA
I took the kart to a mechanic today for a thorough "checkup". He told me that my engine can't use an electric start because it doesn't have two holes on the block for the starter to hook to. Is this true, or is there some aftermarket part that allows it to use an electric starter?
Depending on your particular engine-
There could be a provision for the starter (including mount holes). There could be blank bosses that you'd have to drill and tap. There could be nothing at all.
JonathanEngr
Bostic, NC, USA
I'm assuming you'd replace the flywheel with a toothed flywheel, and the teeth of the starter have to interlock with those. Thus, it would have to mount to the block to wllow it to engage the flywheel.
JonathanEngr
Bostic, NC, USA
Land use--got me stumped there. And ToyStory, you mentioned there might be "blanks"... do you mean simply a part of the block molded for this purpose, but it just wasn't drilled and tapped? How will I find this out for certain? Once I get the kart back, would taking pictures and posting them be enough for you guys to go on? With it being a clone motor I"m not sure if I'll have any luck finding a definitive answer from the manufacturer.
Pictures oughta suffice. And yes- the bosses may be cast, but not drilled. You are correct in thinking you would need a ring gear for your flywheel, or a 'wheel that comes with. Landuse, we're talking about the actual starter motor, not the switch unit.
JonathanEngr
Bostic, NC, USA
Thanks! I really appreciate it. I'll post a few pictures once the kart comes back. If it can be retrofitted for a starter, I can tell it will make my life quite a bit easier!
jhaedtler
Espanola, New Mexico
It will be a lot easier to just replace the engine with one that comes with the electric starter. Check the internet, there are a bunch brand new for under $200.00. I just set my two seater up with a 16 hp with electric starter Engine was only $300.00. Best move I ever made.
JonathanEngr
Bostic, NC, USA
Wow... for under $200? Can you give me some links?
Edit: Well, I found a brand new, 6.5 horsepower, complete *electric start* engine on eBay for basically $200 with shipping. Great reviews for this company, and the engine comes with a 1-year warranty. Since I plan to switch this over to an electric motor down the road, I felt I couldn't go wrong! For goodness sakes, it was only twice the price of converting the engine I had to electric start (if it can even be done). Additionally, the engine I had required a new gas tank (full of rust and debris) and all new springs (since they were rusted). The mechanic told me the labor of replacing the engine versus the labor of replacing all of the parts would be significantly less. Thanks, jhaedtler, for the post!!!!!!!!!!!!!!
