Yeah get somone to recline them
That is a puzzling question
Maybe the washers are touching the seal ( orange bit)
What if u back the nut off?
I assume the wheel has sideways movement then ?
Have u tried swapping the hubs over to eliminate the bearings as a factor
When u remove the hubs just turn the inner race to make sure it's all good
Just because u spun it on a shaft doesn't mean the bearings are good it just means the inner race can spin on the shaft and the bear can stay locked
All bearings have a little drag
If they have absolutly no drag then that is also bad
If I back the night off it spins freely but there is slight sideways movement. As far as I know sideways movement isn't good haha
With the nut backed off, spin the hub & slowly tighten the nut until you notice the hub start to slow down or "grab". It should then be perfect; not too tight & no side movement![]()
If you listen very closely, you can even hear when it hits the "sweet spot"
Are you doing friction drive?? Why have you got a peg on your PTO?
Looks great
The engine was a vertical shaft one from a push mowed
That side mount is The mount
As the commentary suggested, the engine may be a bit tired but, judging by the speed:rpm ratio, I'd say it's geared too high... Looks like you're into jackshaft territory
