Hello all. I found an old Manco Dingo kart for my son that we've been fixing up for him for his birthday in January. It had been sitting out in the weather for about 4 years, so it needed some love. We have the kart cleaned up and painted, aired up the tires (need new ones on rear), and installed a new Harbor Freights 7 HP OHV Honda clone engine (the original Briggs engine was full of water). Attached is a picture from when I bought it, and one taken yesterday.
The question I have is in the pulley alignment. I read on this forum about using these engine on this kart, which is why I went this route. I understood I had to remote mount the fuel tank which was no problem, but I don't remember reading anything about pulley alignment problems. The torque convert system works very well, but the offset (see pic titles nospacer) is causing the belt to wear. I cut a spacer to align the pulleys, but I'm not comfortable with the smaller space the splined hub has on the crankshaft (see pic titles withspacer). Coming from an automotive background, it seems to me the hub (and pulley) would need a bit more support on the crank shaft the the 1/4 inch or so that it would have with the spacer needed to align the inside of the pulleys. Am I correct in my assumption or would it be OK?
If it just comes down to having to replace belts every so often, well then I guess that's what I'll have to do. I don't think there is enough room to move the engine over due to the chain and sprocket on the axle.
Any ideas? I'm sure y'all have run in to this before as this is obviously a very knowledgeable group. Thanks in advance for any help!!
I see you have done a lot of research on you own. Just wanted to let you know, good job! It helps a lot.
