Buying advice
friteful
My pet peeves about go karts are I hate vertical steering columns and I hate steering wheels with the throtle and break stuff on them. I don't like to be hunched over the steering wheel or potentially loose my grip on the throttle or breaks when turning
That a nice looking kart, but there are loads of other second hand karts that can be found running for the same price. It is up to you what you prefer. Not many karts have the throttle and brake on the wheel, so you are OK there
I don't think I have ever seen a go kart with a vertical steering column.
friteful
How fast do you think the first kart I posted a link to would go
They don't give a horsepower :(
Did you read the specs? Let me translate for you
2. Piston Displacement: 168cc
3. Fuel Tank: 4.5 liters 1 gallon
4. Fuel Type: 93#
5. Engine type: single cylinder, water-cooling Not the engine pictured
6. Starting system: manual/pull start
7. Outer dimensions: 1800X980X760mm 6' x 38.5" x 30"
8. Power transmission: chain drive
9. Ignition method: CDI
10. Max power:10.0kW/7,500rpm 13.5hp (Rubbish)
11. Torque: 13.5N.m/6,500rpm
12. Brakes: rear disc brakes
13. Wheel Side: front: 13X5-6, rear: 13X5-6
14. Minimum ground clearance: 105mm
15. Max loading: 100kg/220lbs
16. Max speed: >70km/h >43mph
17. Climbing ability: <20 degrees
B.M.800
TheBeal.
Central PA
Not to through a wrench in the works here... but i would sugest looking on local classified adds before ordering something like that...
You could find something much cheaper, and probably better too. :thumbsup:
jamyers
Buffalo Gap, TX
friteful, you might put your location in your profile, there may well be a board member relatively near you.
Keep after the craigslist, classified ads, and garage sales. Around here there wasn't anything for months and now there are several good deals / projects for around $200 or so.
I'll also second what B.M800 said, for $500 you could probably build your own if you shopped around
beansdaddy78
JR. Member
Carbondale IL.
I have looked on Craig's list and ebay with not much luck
i usually check several different craigslist locations, depending on how far your willing to drive, you may find one very cheap and have plenty of cash left to modify it.
i have a few that i have paid between $30-$150 for .
another thing i do when im looking is post an ad on craigslist wanted: you wouldnt believe how many people dont know how to post an item and just surf CL also people dont always think about the kart in the shed until someone throws some $'s at them
