A Complete Disaster. More like 6 HP Explosion
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Okay so something I never thought was possible, happened to me today. I was riding all around the neighborhood and came out on to a backroad with no speed bumps or traffic. I tied some wire to the throttle arm so I could override the governor for a short time to see max speed. So I did it maybe 3 times as not to hurt the engine and ten I rode around in the field. Which has potholes and I have no suspension. So I hit one, as you ca imagine, and heard a loud thud sound. Mind you, I rebuilt the engine like 3 weeks ago and it was running perfecty. I assumed it was the chain. I had ear phones on so I wasn't aware of how loud it actually was. Turns out, the entire head cracked off of the engine block, and the piston flew out a good 5 feet from the engine. So me, like a dumb@zz, picked it up and dropped it cuz it was burning hot >.< you can see the oil sump, am shaft, pushrods (which are hanging out of the valve case) and all the internals. The connecting rod is completely split in 2. Wha could've happened..?
Excuse the typo's it's late an I'm on A phone.
B man
Tecumseh FTW!
Oliver springs,Tn
may i have your recoil,blower housing, and gas tank? lol. but wow newly rebuilt? did you torque it all to spec?
jamyers
Buffalo Gap, TX
WOW! Your head didn't come off the block, your cylinder bore left your crankcase!
:oops:
I'm betting you've experienced a Tecumseh connecting rod failure. The rod getting overstressed when you over-revved it, but it didn't let go immediately - but when it did...the piston must have been on the upstroke, collided with the head, and BOOM! Tore the engine in two.
I've seen rods punch some nasty holes in crankcases, but never an engine just split in two. Well, except for some gruesome V8 destruction...:ack2:
btw, I'm looking for a Tecumseh carb and air filter...
Jake.B
California-USA
Wow that sucks, i have hit potholes and my engine just dies. I think it is because it throws the piston off balance or like the feeling that when you go down a steep hill or bump fast your stomach feels weird. Maybe it was on the compression stroke and that pothole jarred the piston up and blew the head off?
Brandon1023
needs an oil change
Haha I'm not stressing it. It wwas built in 2004. But that's my luck - override the gov a few times; blow the engine in 2 pieces. I'm sure it was the pothole b/c the bump even hurt me a bit lol. I was like 20 mins away if I Had to push it, but I got my dad to pull me with his car. The piston is laying somewhere in the grass still lol.
Could running It at 3600 rpm for minutes straight have weakened it? I don't think so since you don't see pressure washers blowing in 2 pieces lol.
Also what's the cheapest I can get an 11 hp engine? I prefer Honda, but whatever's cheap. All I have is a 5 HP tech and id rather run in circles and scream., before I use that thing lol. And I just don't see how the rod gave way. They're so fragile. I heard it's b/c Tecumseh's engines are cast aluminum.
B.M.800
TheBeal.
Central PA
Ouch. Would have been interesting to see it happen...
What kind of earphones you got that drown out the engine? I assume you could actually hear music or something?
slideways
First of all its a Tecumseh.. rod failure will happen eventually. And overriding the governor is basically like holding a live grenade. Not very smart especially with these. I've blown 2 of these up on karts with the governor intact. I'd never think of losing it on a Tecumseh without a billet rod first.
Brandon1023
needs an oil change
Well it was a lesson learned. Can you actually rev-proof an engine? I assume the valve springs, rod, and fly wheel all need to be replaced as well as some performance parts. After this, could an engine be ran full throttle w/o risks?
First, Landuse is bang on. You can literally hook an industrial engine to a 55 gallon drum of fuel and run it 24/7 at 3600, no probs. No, I don't think the bumps had anything to do with it. I have thrashed my kart off road with no suspension so bad my body hurt for days.
Theories- First, I haven't had a Tec rod go yet- even at advanced RPM (4000-4500), so I'm not entirely prepared to say, "it's a Tec so the rod will go".
Second- and I know somebody asked this, but I will ask again- Were ALL fasteners properly torqued to factory specification at time of rebuild. Not "Tight enough". SPEC.
Third- Overreving it may or may not have had anything to do with it. A bit of the governor mechanism could have let fly and was rattling around freely in the 'case. A crack could have been present somewhere. Who knows. Oil level could have been low, and/or thrashing might have caused an oil starvation issue at a critical lubrication point.
Fourth- Spit happens. Coulda been total fluke... Glad you're okay.
Jcotz
...wasn't there
NY
I think the bump may have had a small part in the failure, but I don't think it would have been the sole purpose. I think it probably a combination of weakening the rod by overriding the governor extensively, and if something may not have been torqued correctly, so when the rod broke it may have been the cause of the total destruction.
Brandon1023
needs an oil change
You know what sucks? I barely noticed the difference when I tugged on the cord xD on a side note: if I search around right, what is the cheapest I can get a used (possibly) 11 HPengine? Home depot had a 15 HP for around $330 but the webpage said its now discontinued. I'm aware that the shaft is 1 in on bigger engines.
r_chez_08
Should be in the shop...
Cornwall, UK
HMMM...
South Kart3377
Kart designer
Va
Had that happen to a briggs 17.5 on a lawn mower. The rod blew at the bearing, but the block did not split in 2.
By the way Holy Cow. What the heck were you doing with a tec with no gov. My Grandfather told me (And this is just His opinon but he's be around) " So you want a tec, your going to want a new carb, billet Con Rod, Billet Flywheel, and some JB Weld , If you are going to treat it anything like that briggs 8." HEHE. Thats just my opinon. Whatever, I ended up getting a motorcycle instead.
Brandon1023
needs an oil change
Yup easy access to the oil sump lol. I didn't know what happened until I hit the gas and didn't move. So I turned around and saw smoke everywhere and.. yea. The rest is on diygokarts.com lol. I would be the one to pick up the burning hot piston.
Brandon1023
needs an oil change
Teaches me to rev-proof your engine (someone should come up with a catchy one liner instead of "rev proof") before you remove the governor. Hopefully people see this and don't remove their governor unless they know what they're doing, first.
Still don't know where to find an engine around 11-15 HP engine. Any help?
