Axle + Sprocket Queries
Cromatt
Australia, Sydney
Hey, just putting a list of parts together for a road/grass 13hp go kart build and am wondering what the difference between a normal axle and a live axle and the advantages/disadvantages of both.
Also my desired clutch is a noram 1600 14t #40 and am wondering what size sprocket would be appropriate, I was think a 5:1 which would mean a 70t sprocket but not entirely sure. i thought about a TC but have looked around and seen they're not entirely necessary for road/grass driving and they're pretty pricey!
any help is appreciated :)
BTW i am looking at 16-18" tires/wheels and weigh around 95kg so around 200 pounds.
Welcome to the forum!
For starters, you are going to have to gear much lower than 5:1 if you are using 16-18" tyres, as well as the weight of you and the kart. You are going to have to at least go to 7:1 IMO, otherwise you are going to fry your clutch. I would use a 10T clutch instead of a 14. I am not too sure if you get a 10T for a #40 chain.
A dead axle, or one wheel drive, basically drives only one wheel. A live axle, as it says, drives both wheels. A live axle does has problems of its own in that turning can be a bugger, especially on road, unless you have a diff. This will allow the wheels to rotate at different speeds as you turn (the inner wheel turning less than the outer).
You cannot use a TC with a dead axle, but you can with a live one
Cromatt
Australia, Sydney
Thanks for the feedback, I was hoping to do around 25mph would your suggested gearing be appropriate and is there an advantage over a certain tooth pitch (I think that's what it's called :p) because in this type of kart there seems to be only 35 or 40/41 options. And a main issue is having a 1" shaft on the engine and not many reasonably priced#35 clutches are available ( at least not that I have seen)
Here is a speed calculator that you can use to calculate speed, and some info on sprockets and pitch etc:
http://www.diygokarts.com/speed-calculator.html
http://www.gizmology.net/sprockets.htm
The tooth pitch depends on how strong your chain is. A 3/8" pitch is a #35 chain. IMO, a #35 should be fine for you. Because the pitch is smaller, you can get more teeth round a sprocket using the same diameter as a #40/#41 pitch sprocket. That means that you will be able to get more 10T clutches in #35 than a #41 or #42.
If you use a 12T clutch, with 16" tyres and a stock 3600RPM, you should get up to around 29mph.
The problem that you have with your engine, like you say, is a 1" shaft. There are not too many cheap clutches out there with a 1" bore. I also think that you don't really get too many 1" #35 clutches. There is not too much you can do about that though
I agree with landuse, unless you instal a jackshaft for compound gearing you really need a 10T clutch with 16" or 18" rear tires. (unless you instal a huge rear sprocket, but then you'd have ground clearance issues)
Noram does make a 1600-series, 10T clutch for #40/41 chain, the Noram part# is NA160153. (Its rated up to 15HP) If you cant find one in Oz, Its available from the states here: http://www.out2win.com/catalog/noram.html#1600
Noram also makes the 1" bore Enforcer model with a 10T, #40/41 drive gear: http://www.out2win.com/catalog/noram_enf.html
It cost more but its a larger diameter, more heavy duty clutch that would stand up to much more abuse. Noram doesn't publish the HP rating of this model, but lots of kart racers report very successfully using this model on engines with 40+ HP.
The only drawback to using either of these 10T models is they are the outboard-only mounting style because of the small diameter of the drive gear. This means you cant instal the clutch with its drive gear pointing towards the engine, It has to be facing outward and the drive gear will end up way out at the very end of your engines output shaft. Although this isnt a problem as long as your kart has enough room and your axle sprocket will line up.
Cromatt
Australia, Sydney
This concerns me a tad as all the 13hp engines I have looked at state they have 2600rpm power, not sure if that's right or I'm missing something because that definately has confused me. I never saw that model noram clutch Anderkart so that is definately a better option I think the enforcers a bit pricey including shipping to oz. so would I be ok with a 6:1 ratio if I get a 60t sprocket on the rear with the 10t noram or will it burn out the clutch?
The engines you refer to probably make peak torque around 2600RPM. You will likely find they are factory governed to 3600RPM. Find an example of an engine you are looking at, post it here, and we will verify it for you.
I agree with toystory, here's three 13hp engines from OZ ebay showing 3600rpm.
http://www.ebay.com.au/itm/Dinomart...70?pt=LH_DefaultDomain_15&hash=item2ebc535d32
http://www.ebay.com.au/itm/13hp-4st...84?pt=LH_DefaultDomain_15&hash=item41626b039c
http://www.ebay.com.au/itm/13-HP-HO...35?pt=LH_DefaultDomain_15&hash=item19bf9e2f3b
All those 13hp engines are copy/clones of a Honda GX390. You can download its specifications/owners manual here:http://engines.honda.com/models/model-detail/gx390
All these Industrial engines come with the governor system calibrated to a max rpm of 3600 because that's the industry standard speed needed for operating generators, water pumps, etcetera to full rated capacity.
That 10T Noram 1600 with a 60T sprocket should hold up fine with 16" tires, as long as your not trying to climb steep hills or doing a lot of low-speed/stop and go type riding were the clutch would be constantly having to slip. Your estimated top speed would be 29 @ 3600rpm.
If you used 18" rear tires, I'd suggest a 70T axle sprocket where your estimated top speed would be 28mph @3600rpm.
To achieve higher top speeds, you'll probably find an adjustment screw on your engine you could turn to achieve around 4000rpm. Or you could completely remove the governor system and get around 5000rpm from any of those GX390 clones.
Cromatt
Australia, Sydney
Great thanks for all your help i've decided to go with 16" turfsavers so i'll use the 60t sprocket. Another question back on the topic of axle's, if i buy this axle and this sprocket hub, i have to buy 1/4 keystock's such as this which i think (correct me if i'm wrong) just slots into the axle and then the hub uses it as a gripping point? if thats correct do i need locking collars on either side of the sprocket or is the keystock enough??
this is one example here which says 2600 RPM max power output and 2500 max torque not sure if this is correct or not :S
Okay- I looked over the specs on this engine- It indicates max HP at 2600RPM, and max torque at 2500RPM. It does NOT indicate max RPM value. I would bet my next paycheque that it's governed to a max RPM in the 3600 range.
A word on max HP- EVERY hp/torque curve I have read on stationary industrial engines indicates a peak torque value around 2500-2600RPM. Every curve I've read indicates peak HP at 3600RPM (and rising). Extrapolating the curve indicates a rise in HP (with a limit of course) ABOVE 3600rpm. So, I fail to see why the above specs indicate max HP around 2600rpm. I suspect somebody simply f*cked up the specs somewhere, and peak HP really is around 3600rpm.
Yep, i agree with toystory.
Cromatt, those parts look fine as long as that axle has its keyways machined in the locations you want your sprocket and brakes located. Some axles have a keyway machined down the whole length, these would give you more options on where your sprocket and brakes are located. Have you decided on what type of brakes you'll be installing, and where you want the rotor (or drum) located on the axle?
Yes your correct, the hub uses a key as a gripping point. That sprocket hub has a setscrew that you tighten up against the axle to hold it in place, so you shouldn't need any lock collars for that hub.
Cromatt
Australia, Sydney
The brakes i have been looking at are the stens mechanical brake and 1"bore disk seen on this page, the set up i was looking at was something along the lines of
. using a throttle cable and housing attached to a pedal like a throttle, or alternatively use a brake rod set up
I would strongly suggest if there is space use shaft collars as a added measure to secure a sprocket or brake hub on a shaft. Last year on my bike, I had my brake hub walk the key out I didnt know as I went out for a ride. I did noticed a bit of lag on stopping but I knew the brakes were a bit finicky to setup. Turns out when I got home, the hub welded to the shaft an thats what finally stopped me. It was quite the b-tch to remove the hub.
Luckly I had got home in one piece. The shaft and hub were not that tore up when disassembled. Now I have collars on all of my hubs for wheel/brake and drive sprocket. It wasnt all that much extra to buy anyways.
That axle your planning on using has a low price but I just cant tell where its keyways are machined in. It might work out fine on your kart, but If you got an axle with its keyway machined down its whole length you could mount your sprocket and brakes wherever you wanted.
These axles:http://out2win.com/catalog/axleus.html cost more, but they're probably much higher quality and have full-length keyways.
Have you decided on what rear rims you'll be using? You'll need to know what type of mounting/bolt-pattern they have before ordering your axle...
Lots of guys here have reported those mechanical disk brake kits dont offer much stopping power. They require a lot of pedal force so you'd definitely want to use a strong brake rod instead of a throttle cable.
Cromatt
Australia, Sydney
do you think a band/drum brake would be more efficient? a hydraulic brake calliper kit is out of the question due to price though but i think i might now use a brake rod assembly rather than cable if it requires less pedal slamming.
the rear rims are These ones there which have a 1/4 keyway and if i use the WMS 1" solid steel axle i will have to put locking collars like This i assume as the axle doesnt have a threaded end or is there another way of doing it?
that sounds like its definitely worth putting collars around and they're not to expensive either thanks for the tip!
I wouldnt trust just only lock collars to hold those wheels on the WMS axle. You need an axle with threaded ends and snap ring (or some kind of lip) to tighten the wheel up against.
I'd probably choose those Stens Mechanical disk over drum brakes. They might work ok for ya, I'm just thinking your kart might end up being fairly heavy and Its always nice to have lots of stopping power. Some other options might be installing a pair of those Stens Mechanical disks and design a dual brake rod from your pedal to actuate both. Some guys get a low price buying the used disk brake systems from an old motorcycle and then adapt them to their karts.
Cromatt
Australia, Sydney
The WMS axle comes with snap rings as well if I recall correctly, if I was to install 2 stems mechanical calipers would it be viable to move the sprocket outside the frame near the wheel and put another disk where the sprocket originally was? That will probably turn out to cost around $90, I'll have a look at motorbike brakes and their cost and see which ones more viable.
As long as your axle had a full keyway, you could mount the sprocket and both disks anywhere you wanted.
The snap ring slot is at the very ends of those WMS axles:
Those axles are made to use racekart style wheel hubs like these:
(then after the hub is clamped on the axle, the snap ring goes on the vary outside and are just used as an extra safety measure so the hub couldn't ever slide off)
Cromatt
Australia, Sydney
Thanks for all your help everyone, i'll start a build log when i first start and i'll keep it updated and if i have any questions i'll ask. thanks again anderkart, toystory, landuse and mckutzy!
