Kenny_McCormic
Kartless....
Man, I should have videoed arc welding the spindles on my go cart.
Dangit... too bad 4 seconds later, faded into like the rest of the welds. Dark and black.
lol i lost what i was typing so here we go again:
Whats a safe weld? When it's strong enough for its purposes. An offroad kart will probably into get into a crash with another one, but maybe a tree or rock. Get a big hammer and if you cant break test welds, thats pretty much your answer. Cleanliness of welds isnt a requirements, but it happens that usually the strongest welds are also the cleanest and most efficient. Maybe the ugly weld can hold 800lb while the nice one 1500lb but either will probably be fine for your purposes.
If you wanna sell stuff you weld or weld professionally, or show your stuff in a car show or something, then the requirements change completely as people get very picky, but if its not about looks, just test the strength and if it passes youre good.
If you can break the weld, i guarantee your body and all the inertia of a moving kart will certainly be able to break it too, so test it very well.
As for where to buy steel and what to buy, it depends on the complexity of the frame. I stick to 1" square 16gauge tubing which is fine if the frame is triangulated and not just a ladder chassis but has some good vertical elements. the simpler the chassis, the thicker stuff needs to be. (i always trust the better design anyway, safety first)
