How to paint a car?
oscaryu1
Wondering if anyone had any experience in this area? Or know of any online guides :eek:
Basic questions:
Stripping down the bare metal vs sanding?
Grit of sandpaper?
What do you apply in order? Epoxy... the actual paint.. sealer... (as you can tell, I have no idea).
Thanks!
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Whether you strip to bare metal or just sand the paint is your choice. Just know that starting with bare metal requires using an etching primer to promote adhesion to raw metal, but provides better results.
Google goes a long way here.
Choose from a single stage or double stage paint. Double stage requires clear, so you'll have a shinier finish but more upkeep. It also makes touchups more difficult. Single stage isnt as shiny but is easier to keep and touchup.
Do yourself a favor and buy a nice, long sanding block. Use it for final body work.
oscaryu1
Thanks! I was told I should use water-soluble stripper and not chemical stripper? (Aircraft remover I assume is chemical?)
devino246
Lynchburg, VA
Not sure, Ive been working in my great uncles shop & hes got a giant a$$ air compressor so I just use an orbital sander.
oscaryu1
Is it similar enough to electric orbital sanders? D: I wouldn't mind getting a DA but I have a 1.5hp compressor :\
oscaryu1
yush. any idea what type of sandpaper I'd need? I don't wanna get down with your homeimprovement grade 80 grit and end up with numerous scratches :(
TorqueRanger
Like everyone said check out Google and there alot of info out there... I have family that spray cars gallons of rustoleum and it come very good.. 1.5hp compressor but what gallon and cfm are you working with ???? What type of gun are you using ???
devino246
Lynchburg, VA
Use 80 to get through the clear/base coat, then switch to 180 for the rest.
The problem with Rustoleum: get gas on it and your done. Automotive paints arent affected by gas.
A 1.5 compressor wont run any type of sander for much more than a minute. Even with a giant tank, you wont get very far before you have to stop.
oscaryu1
Yesh, it's a 7gal with a secondary 11gal HF tank lol. Takes 15 minutes just to fill >_>
2.9cfm at 90psi... it's terrible lol. Craftsman ftl.... the HF equivalent costs less and puts out 4+cfm.
oscaryu1
Got the fenders off... one's done for (previously wrecked), but the other should be fine. The paint on this is incredibly thick... 3mm+... is that normal?
oscaryu1
This is a '87 Camry lols :3
Well I took some 80 grit to the fender for a minute... god this is gonna take quite a long time D:
oscaryu1
xD
Random (possible stupid) question, would it be a idiotic idea to reinforce the inside of a fender by tacking/TIG'ing small bolts to the fender underside, then bolting some square tubing to it? lol.
Btw... what's this aboot painting your car after just scuffing the factory paint?
Rustydog2010
NZ Nutta :|
New Zealand
I have painted a few trucks and trailers. I normally start with a 60-80 grit if there is a lot of excess paint. Then just wipe it down with thinners.
Prime it once and do nothing. On the second coat sand it down with a 180-220 grit paper, once again wipe it with thinners.
Then two coats of top coat, sand it with a 380-400 grit paper, then a final coat. Then a clear coat.
This is a long winded way of doing it, but the results were pretty good. Most of the skill comes in using the spray gun, making sure there is little over spray, the ratio of thinners to paint, etc..
If you are going to fill it full of bog thats a whole other story, lol.
oscaryu1
I don't mind taking longer, the longer and better looking the better lol.
This OEM paint is incredibly thick though... is using stripper cheating?
