HELP!! i apparently suck at wiring.
B man
Tecumseh FTW!
Oliver springs,Tn
ok so me and my friend are trying to hook up out side cab lights to his truck. his truck is an old CSX rail road truck. it had a light on its roof before and i thought. why not use those wires to hook into. and i have confirmed with another simple test light they still work. ok iths kinda hard to explain the setup so heres what it looks like. this should work right?
B man
Tecumseh FTW!
Oliver springs,Tn
whats happenig is that when i ground the switch the switch lights up on the on position,but when i grounded the lights the switch stays light up on or off. and both ways the lights still won't work!
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Are you sure you have the switch hook up correctly? Your making this way harder than it has to be.
newrider3
Colorado
You should have a SPST (two prong) switch, not a three prong one. You don't need a ground going to the switch, it is just there to complete the hot side of the circuit.
B man
Tecumseh FTW!
Oliver springs,Tn
well the guy at NAPA thought it was just so the switch would light up.but i undone it and the switch still light up. so idk im kinda stuck
B man
Tecumseh FTW!
Oliver springs,Tn
hehe well i learned what not to do....don't bypass switch. although after takeing the switch out of the equation the lights worked. does that mean bad switch?
It means you had it wired wrong, OR it was bad. Post the switch details including terminal markings. Switch can be verified with test light or meter.
:iagree: It sounds like you just had an Illuminated type switch that was mis-wired:
It can be wired wrong multiple ways- what markings or symbols are on the switch next to the terminals?
EDIT- I just did a quick count- 3 terminals means it can be wired WRONG five different ways!
