Hey Guys I Got A Go Kart But The engine it had was pretty bad so I put a 3hp Briggs engine on it and I bought a clutch, I was wondering if it could pull me and my bro together we weigh about 220 together and if it could how fast would the clutch burn out,?
I know you all like Pictures But It's Nothing Special It's and old faded 1 seated go cart with a rim sprocket? not the whole axle(live axle I think they call it?) and I think its monocot? well it says that on the bottom where you put your feet! Thanks For Reading! |
It Was Of A Rototiller!
![]() Quote:
![]() It wont have a lot of torque but it should pull you guys around fine. |
LOL Sorry I will put pictures then but don't make fun of me cause its little! but I mean how long will the clutch last? like today I had it started and the cluch made some weird noise and got, I guess "locked" and made the engine stop?
![]() Quote:
If you want it to carry that kind of weight, you'd need to gear it down which means you won't get a high top speed. Gearing for speed will definitely shorten the life of the clutch but, by how much is anyones guess...
2013 Build-off Winner - http://www.diygokarts.com/vb/showthread.php?t=21076 |
The only way 3hp is going to haul that much weight around, is geared waaaay low. Unless you guys don't mind topping out at 5MPH, you'll want to consider a larger engine.
Treat it as you would an aircraft frame and you should have no problems. -Name Withheld The Manual- "Just the manufacturer's opinion of how to put this together."- Tim "The Tool Man" Taylor Put down the wrench, and come out with your hands up!- Me! Wrench, Wheel, Wreck, Repeat... |
#7
Thanks Guys !So Turns out I gets us going but it takes a couple of seconds to get at "High Speed". I Mean It WILL Pull Us But Now My Fear Is Burning the clutch lol Theyre a little Too Expensive! & I Have another Question, Have You Guys Experienced the Clutch making a Noise and kind of "Engaging" and making the engine turn off?
#8
The clutch problem you describe is a lack of lubrication. There is a bronze bushing in there that the outer drum rides on. It needs to be lubricated frequently (every couple hours of operation) with 1-2 drops of clean engine oil.
At this point, it may or may not be damaged. Take the clutch outer drum off and inspect the bushing. Wipe clean with a cloth but do not use a solvent. If it's not damaged, put 2 drops of engine oil in there and spread it with your (clean) finger. Reassemble and install. If it is damaged, purchase a replacement. Do not over-oil. Excess oil can work it's way onto the clutch shoes. Contaminated with oil, they will not grab properly.
The Following User Says Thank You to Doc Sprocket For This Useful Post: | ||
Martinechnology (04-07-2013) |
#9
Thank you! I will get to that!
Thread Tools | |
Display Modes | |
