Go Back   DIY Go Kart Forum > Building Plans And Advice > Photo Gallery & Project Log
Closed Thread
Old 03-18-2013, 07:44 PM
koltynsherman koltynsherman is offline
Default mini monster truck
Hey guys, my Dad and I have been redoing my mini monster. I'm just going to list what I have done to it. The frame and body are original everything else is new. I extended the engine mounting plate oh yea btw I have learned how to weld and have a 220 volt wirefeed mig welder.okay back to topic lol. I installed a new 16hp duromax engine, a custom welded exhaust stack, a new 40 series clutch, 4 new carlisle badlands with new wheels. All new bearings and new paint. My Dad painted the body and I did all the frame work. I strenghthen the front end, installed keys in the hub to make it a live axle instead of one wheel drive. I also added some little things like a horn and fog lights and will be installing a stereo and winch. I have also started building a trailer to pull behind it. Let me know what you think.
Old 03-18-2013, 07:46 PM
oh and forgot to mention, i cut off the old band brakes and welded up disc brakes.
Old 03-18-2013, 07:56 PM
Doc Sprocket's Avatar
Lookin' pretty dang good!
The Following User Says Thank You to Doc Sprocket For This Useful Post:
koltynsherman (03-18-2013)
Old 03-18-2013, 08:00 PM
i will try and put up a video in a few days.but dont have a youtube account yet.
Old 03-18-2013, 08:08 PM
souperman000's Avatar
souperman000 souperman000 is offline
Got any pics of the trailer? What are you planning to do for the hitch? That thing looks awesome!
It's hard to help people that won't help themselves.
Old 03-18-2013, 09:02 PM
Default trailer
these are the only pics i have right now but im done with the hitch. im half way on the trailer i just used a regular truck reciver hitch and cut up four mower blades and cut the angled ends off so they were just flat plate and welded them into a square for the hitch to slide into. then welded it to the frame and before i welded them together just lined up the pre existing holes of the mower blades so i can slide a pin thru the hitch.
  #7
Old 03-19-2013, 02:01 AM
landuse's Avatar
landuse landuse is offline
That is one sweet truck. How does she drive? What gearing do you have set up?
You have done a great job for a youngster. I love seeing young people get their hands dirty
The Following User Says Thank You to landuse For This Useful Post:
koltynsherman (03-20-2013)
  #8
Old 03-19-2013, 04:08 AM
Orange Krate's Avatar
Orange Krate Orange Krate is offline
Very Nice! I remember seeing these raffled off at business openings when I was a kid.
The Following User Says Thank You to Orange Krate For This Useful Post:
  #9
Old 03-20-2013, 07:20 AM
I'm running a 65 tooth on axle and a 10 on the jackshaft .I was running a 12 on the jackshaft. but she was to fast she would do every bit of 45mph but it was to fast .with the 10 tooth on the jackshaft she does about 34mph but even with a live axle she can spin out about 20 feet and break loose on concrete It awesome once you got over about 38mph she starts to hop because of the tires.
  #10
Old 03-20-2013, 08:02 AM
mysteryboy28's Avatar
mysteryboy28 mysteryboy28 is offline
if you're gonna be hauling things, you might want to consider setting up a secondary jackshaft so you can go even lower than 6.5:1 - like 8:1! (yes, 8:1 is LOWER than 6.5:1, that would be like an 80 tooth sprocket on the axle, which would probably cause ground clearance issues) then you will have gobs of torque, and some good hauling capability without burning up the clutch (torque converter i assume?).
  #11
Old 03-20-2013, 08:11 AM
cumminsbayou4x4's Avatar
cumminsbayou4x4 cumminsbayou4x4 is offline
does it off road good with the gearing? does it want to flip on hills?
  #12
Old 03-20-2013, 09:50 AM
Default Gearing
Quote:
I actually have a 60 tooth on the axle and I dont think I have enough room for another jackshaft but I'm not going to be hauling the trailer all the time I built it to put a cooler and chairs on so when we're at like a car show we don't have to carry stuff around.do you think it will be okay.thanks
  #13
Old 03-20-2013, 10:13 AM
Default Offroad
Quote:
Yea it off roads good it'll do donuts and and spin out. as far as hills it hasn't tried to flip on me .except it almost did when i took a corner to quick but luckily it didnt flip .but it climbs hills no problem the motor hardly works at all it will bog a little if you don't give it enough throttle going uphill .but it'll spin the tires no problem uphill it had plenty of power to do anything I want and I'm hard on machines.i like the gearing because I still have speed and alot of torque.
  #14
Old 03-20-2013, 11:17 AM
and that's what matters! if it works, don't change it!
  #15
Old 03-22-2013, 12:19 PM
msanders03 msanders03 is offline
Junior Member
what size are the tires and wheels?
  #16
Old 03-23-2013, 09:16 AM
Kelly Wood's Avatar
Kelly Wood Kelly Wood is offline
The Mad Kartist
Excellent work guys! Love the exhaust lookin pipe in the bed.
  #17
Old 03-25-2013, 09:02 AM
Default tires and wheels
Quote:
they are 22x11x8 carlisle badlands all the way around with just normal 8 inch wheels im going to pe putting hubcaps on to make it a little more aggressive lookin.
  #18
Old 03-25-2013, 09:05 AM
Default exhaust
Quote:
it was my dads old truck exhaust tip so i welded it to the header.its really loud it has a real throaty sound to it.
Closed Thread
