Go Back   DIY Go Kart Forum > Announcements & Suggestions > FAQ & Articles
Closed Thread
Old 12-10-2013, 08:06 PM
Scout's Avatar
Scout Scout is offline
Nutjob
Default Predator 212 Engine - Collected Info
I'm collecting Predator 212 info and thought I'd make a thread on it.
The easiest things to do are to replace the stock intake and exhaust. The intake is designed to do a couple things, one is to be compact, and another is to keep the intake noise down. Unfortunately it is also restrictive, and restrictions cause a loss in power, so it's a good idea to ditch it.
The exhaust is supposed to be a spark arresting type. that, plus the baffles to keep it quiet, also is restrictive. Actually, the quieter the muffler, the more restrictive it is.
Here is a webpage where the 212 was ungoverned, with a new intake and exhaust. According to the article, the motor is rated at 6.5 hp (but we knew that) and with these mods it put out nearly 9 hp at 3600 rpm (governed speed) and 9.8 at 4700 rpm. It goes on with a few more mods to pull a max of 12.13 hp.
http://www.kartpartsdepot.com/help_answer.asp?ID=11
You might read something about the Hemi head motor. I don't know the specific differences, I can only find that the hemi head motors are better, they came on motors built after June 2013, and have a cast aluminum valve cover. Here's a thread about how the hemi head flows.
http://www.oldminibikes.com/forum/en...hemi-head.html
According to this post http://karting.4cycle.com/showthread...ll=1#post42607 it sounds like you can use a head from a GX160 (5.5 hp) on a Predator with a stock piston and decent cam, and get 17 hp. I wouldn't try it unless I had money to burn.
Here is a debate on ethanol vs methanol. It sounds like E85 is a cheaper alternative to methanol. I would think that if you were going to run methanol you'd want to bump up the compression and build a motor for the fuel. Since I can't get E85 where I live, I'll just stick to regular.
http://www.oldminibikes.com/forum/759098-post33.html
Here is a thread on an all out Predator build. It was at 15 page when I linked it here. (He had just over $1000 in it too) http://www.oldminibikes.com/forum/ho...upgrade-s.html
Parts websites
Cams and valvetrain http://www.smallenginecams.com
Predator engine parts http://www.parsonsracingengines.com/...20kart%20parts
"Hop up kits" (cheap way to get a bunch of parts) http://www.nrracing.com/category-s/1819.htm
Torque specs http://brainlubeonline.com/clone/
Fuel injection? Heck yes! http://www.brainlubeonline.com/clone/fuelinjection.html
Video time! I don't know this guy and have nothing to do with him, I just thought he has some good videos.
I highly discourage this. It is no way to accurately lighten a spring. With all the money this guy spent on his engine, he should have just bought the right springs.
http://www.diygokarts.com/vb/showthread.php?t=2473 Pile o'crap http://www.diygokarts.com/vb/showthread.php?t=23757 Lights!
The Following 11 Users Say Thank You to Scout For This Useful Post:
adsum (10-14-2014), Axx3d (01-11-2015), Ckolin725 (08-05-2016), Doc Sprocket (12-11-2013), firemanjim (12-23-2013), Jr. Mechanic (01-03-2017), landuse (12-11-2013), machinist@large (12-11-2013), Oxymoron (12-11-2013), rocketkart (12-10-2013), Slimmpd (11-22-2016)
Old 12-10-2013, 09:22 PM
Br@ndoM@n Br@ndoM@n is offline
Dude with a gokart, a MIG
Location: New Mexico (Not Dirty Poor Mexico, NO HABLA ESPANOL AMIGO! Grassy ***.
Thats what I may do. I currently run a "real" gx160 with a bad carb so I may just get a predatory 212 and use my gx160 head on it. probably head and valve work to atleast match gx200 head flow.
Old 12-11-2013, 12:47 AM
landuse's Avatar
landuse landuse is offline
Thanks for the post. Great info
Old 12-11-2013, 04:00 AM
Oxymoron's Avatar
Oxymoron Oxymoron is offline
Newbesque builder.
Quote:
Sticky? Or are there already too many?
Hi. I'm Chris.
Old 12-11-2013, 04:14 AM
landuse's Avatar
Quote:
Mods will discuss.
The Following User Says Thank You to landuse For This Useful Post:
Old 12-11-2013, 07:35 AM
Oxymoron's Avatar
Newbesque builder.
Mods will discuss.
Sounds good bud. In the least, maybe add it to your "helpful links from the forum" thread?
Hi. I'm Chris.
  #7
Old 12-11-2013, 10:36 AM
landuse's Avatar
Good idea
  #8
Old 12-11-2013, 03:28 PM
machinist@large's Avatar
machinist@large machinist@large is offline
I tripped over the "8000 RPM" test video last week; I thought it was just a one off thing. So this guy's legit? Based on the way he presented that video, I wasn't real interested.....
If you think the info is legit, I'll give it a good look (the video's, I mean; oldminibikes.com usually doesn't mess around). Anyone else?
  #9
Old 12-11-2013, 04:02 PM
Only real prob I see is he making the intake as smoth as possible which is a no no. Pretty much any engine builder will tel you its best to leave intake a little rough to help with fuel atomization. Exhaust port wants to be as smooth as silk. That long duration cam is nice. wonder which is better to gain lift, from cam or higher ratio rockers. Im thinking cam.
  #10
Old 12-12-2013, 09:02 AM
Scout's Avatar
Nutjob
It appears legit, but I don't remember him having a tach of any sort to verify 8k.
After all that time and money spent, I'd like to see it on a dyno.
There were some other things I found, like stud kits, roller rockers, billet side plates, etc, but I didn't think that sort of stuff is necessary for a yard kart. My personal plan is to change the air filter and exhaust, yank the gov, and leave the rest alone. If that gets me 9+ hp like that article says, I'll be happy.
The Following User Says Thank You to Scout For This Useful Post:
machinist@large (12-12-2013)
  #11
Old 12-21-2013, 03:28 PM
Half-breeder Half-breeder is offline
"Edit" button removed
... this isnt a mod info... more so a factory info vid...
My channel... https://www.youtube.com/channel/UC9tLeV67lsEIrulgHA6t0wg
  #12
Old 04-14-2014, 03:03 PM
Louie The Lot Lizard Louie The Lot Lizard is offline
Default 212 Carb flow data
Thanks for all the info so far.
It looks to me that the stock carb is pretty restrictive, I don't know how people are getting 12 HP with this carb or the bored out versions.
Does anybody have flow data for these, or a Honda GX390 carb?
I even thought of a Tilly as used on some 1/4 midgets, but it looks like its too big. I think it might work but would take an air horn about the size of trombone bell and about that long. It would be ugly as **** but might play some sweet notes!
I don't want a big bog at 3500 RPM. I think a Tilly flows about 50 CFM, maybe something between 30 and 50.
Been thinking of building a dyno, maybe I should build a flow bench.
I like to tune for best average torque.
  #13
Old 04-29-2014, 09:57 AM
tuneman tuneman is offline
;1Ok i just watched ALL videos of this guy........ for a yard kart......this would be perfect....for the average guy that can read a txtbook.......and use a piece of sandpaper....never smooth the ports......fuel atomization is key..........never seen him go for advanced timing!? .....race engine? however i did agree that he did buy all of the proper parts (except for valve springs and correct size head dowels). what was up with the valve spring lightning!? why eve;1n do that if your building a race engine correct springs WILL be needed for tech........if your using a fuel pump.....why mount the tank above the carb?..... he stated racing engine!.... he hit maybe 6500 ..... however a S/A gas carb?.....most ive gotten is 7650 was with a custom top end cam grind from tim isky ( www.smallenginecams.com ) and 26 lb springs, billet lifters, loose bearings and low tension rings....only one engine we built made it that high and at that didnt really make enough power curve like claimed until we switched to alky.......you know when your mashing the pedal on the straights of greenville (J&J's)and hittin 8k trust me...better have good tires.... overall....the man did build a pretty snappy engine but FOR A YARD KART....not a racing engine...no carb work noted.....no real actual time dyno testing, no secrets to be learned.... id like to see the engine in action....every engine is snappy with no load....even stock flatheads (6.1:1 comp. ratio)
The Following 3 Users Say Thank You to tuneman For This Useful Post:
adsum (10-14-2014), kart bruiser (09-03-2014), Metal_Rott (07-04-2014)
  #14
Old 04-29-2014, 10:02 AM
and for the record i think ALVIN L NUNLEY should see this
  #15
Old 05-05-2014, 09:19 AM
I've done a little more research, while I don't have a flow bench I found that a GX390 carb measures about 22 mm and should flow about 30 CFM. Someone makes an intake for this swap. (To a predator). This looks to be a viable setup for milder cams and should really perk these engines up in the 4000 to 5000 RPM range. Also would be less money than a similar sized Mikuni style which would flow a little better.
Based on what I've seen in our local club, this should be a good setup on our tight turns and long straights. Now I wouldn't say that a bigger carb and more cam won't make more "putty" but there is a limit to traction, I would rather have a flatter torque curve and an easier driving kart at this stage of the game. Some of our guys have went to bigger cams (than say a CL 1 or 2) and have had no performance gain if not a negative gain because of the restricted carbs (even though bored).
Thanks for this forum, it has been a real help.
Hey, that's not broke, it just needs fixed!
The Following User Says Thank You to Louie The Lot Lizard For This Useful Post:
Scout (05-09-2014)
  #16
Old 07-04-2014, 12:20 AM
Metal_Rott Metal_Rott is offline
I wish this guy installed this engine on something for us to see T_T
  #17
Old 07-18-2014, 01:12 AM
mrdeadman1 mrdeadman1 is offline
ok so where can i get secondary jets for my predator?
  #18
Old 07-18-2014, 11:22 AM
Scout's Avatar
Nutjob
There is no secondary jet, just the main.
  #19
Old 07-21-2014, 09:26 PM
ok the first article mentions a pilot jet that is what I ment just used the wrong term
  #20
Old 07-24-2014, 07:46 AM
Scout's Avatar
Nutjob
This is the one I ordered. The short fat one screws in the bottom, the long skinny one screws is press fit. Mine popped out with a little push from a screwdriver. And you only need one of the short fat ones, start with the .038 and see how the plug looks after awhile.
http://www.ombwarehouse.com/Racing-Jet-Kit.html
Closed Thread
