Old 08-02-2007, 09:34 AM
GoAlterBridge GoAlterBridge is offline
Default Go Kart Spindle Questions
On go kart spindles, do the tubes have to be exactly 1/2" I.D.? Or is 9/16" okay?
Edit:
Since I'm on the subject of steering right now, I have an 1/8" pin holding my steering together, should I just weld it solid?
Old 08-02-2007, 03:39 PM
robertdjung's Avatar
robertdjung robertdjung is offline
Administrator
? not following you, sorry.
Old 08-03-2007, 02:41 PM
jeff_man jeff_man is offline
if you going to use the 9/16 i would use a half inch bolt going through it if that is what u mean
Old 08-03-2007, 04:36 PM
Robert: going through the steering shaft, and the pitman arm, is a 1/8" type of "pin" that makes it so when the steering shaft turns, so does the pitman arm. Heres a picture:
file:///C:/Documents%20and%20Settings/Pat/Desktop/Go%20kart%20steering.JPG
Also, the spindle tube, it calls for a 1/2" bolt. I have the half inch bolts, and I need to know if I can use 9/16" I.D. tubes, instead of 1/2"
Old 08-03-2007, 11:25 PM
Administrator
well, the whole idea is that it's tight. I wouldn't use something with a 1/16 of "slop" in it.. I'd either go larger, and get some bushings, or make it tight. you don't want your steering rattling at 20+ MPH!
The Following User Says Thank You to robertdjung For This Useful Post:
GoAlterBridge (08-04-2007)
