Jacka$$withawrench
I found this for $15, is it a good deal?Two Questions:
1) Is the right angle turn in the bung important? Or can I just flow the fuel straight down?
2) How did you find the bearings for so cheap? I'm looking at replacing one of mine (it stuck, but works with heat and WD-40) but cheapest I could find was this: SKF - 1-3/16" ID x 2.4409" OD, 3,380 Lb Dynamic Capacity, Insert Bearing Insert Bearing | MSC Industrial Supply Co. (mscdirect.com)
Pillow Block Assembly | 3013-2806 | BMI Karts and Parts
