Total PITA!
So the 9t refused to go on the new shaft so I mixed around old parts with new to get things together.
(I had to bore it over a bit and lightly sand the shaft I used it on to begin with)
I ended up needing a little more header clearance off sheaves (probably fine but I wanted to be sure) so I angle cut it a few times to tip it out and cut it off lower to swing it back in towards the frame. It's together and ready to test run tomorrow.
