Closed Thread
Old 09-09-2019, 12:51 PM
shewannameetkarty shewannameetkarty is offline
Default Is it possible to use a torque converter on 1wd?
What the title says
Old 09-09-2019, 02:10 PM
JTSpeedDemon's Avatar
2019 Build Off Winner!
Generally no.
It's very hard to get the chain alignment and clearances just right.
Currently Flathead-Crazed
Old 09-09-2019, 02:37 PM
Dingocat's Avatar
Dingocat Dingocat is online now
Broke
Is it possible? Yes. Is it worth it? No. You would have to move the engine sideways and probably up to fit it all. And then you would probably just spin the tire if you did get it to work.
If it's not scary you're not going fast enough
Old 09-09-2019, 06:08 PM
anickode's Avatar
anickode anickode is offline
Quote:
Unless you were building a reverse trike with a fat rear tire. Then, totally worth it. Otherwise, no.
"Well that would be a bomb."
Old 09-14-2019, 04:54 PM
jeffone jeffone is offline
Junior Member
Anything is possible
Old 09-15-2019, 01:02 PM
BigWes's Avatar
BigWes BigWes is offline
I bet you could leave a black mark on asphalt if you did though! But seriously, all you would do is smoke tires with it!
This ain't rocket science boys!!!
Closed Thread
