Old 06-28-2020, 11:54 PM
WolfBuilt WolfBuilt is offline
Default Yard kart/backyard dirt oval build
First post here. Been lurking for a minute for all kinds of great info and tech on my first kart build. Found some really great insight!
Wanted to share my current build and the story behind it. I grew up racing flat track/tt quads. So when my brother-in-law and a bunch of his veteran circle track friends got together and formed a yard kart league, I had to jump in! At first, I thought it was going to be pretty much an “open/modified” run whatcha brung situation, but that quickly changed once they had seen what I was building. I was promptly told that my kart was out of tech specs for what they would allow to run on the short 1/10 mile oval. Regardless, I continued to build the kart how I wanted.
So what is it that I’ve built? I found what I believe to be is a 2012 Charger Magnum chassis on the good ol’ FB marketplace for what was a pretty reasonable price for a not so strong running predator 212 stage 2 kart with a spare clone, starter box, oil, weird wheel/tire setup and some random tire prep. I was set to start my build!
I tore the kart down to the frame, prepped for paint, made a lengthy parts list and went at it.
As it sits now, here’s the set up:
Chassis:
2012 Charger Racing Chassis Magnum
Stripped, detabbed, shortened front bumper and painted
Tires/wheels:
Package put together by Carlson Motorsports/Vector Cutz with mounting, balancing, cutting and prep. Highly recommended!
RS Tires
11x6.5-6 Hoosier treaded D30A
RS Wheels
Douglas Q+ black powder coat 9.5”
LR Tire
11x5.5-6 Hoosier treaded D30A
LR Wheel
Douglas Q+ black powder coat 8.5”
LF Tire
LF Wheel
7.5”
Drivetrain:
Tillotson Racing 225r long block
.010 copper head gasket
ARC Racing PVL Ignition Ultra Lite Billet Flywheel
Blue PVL ignition coil/magneto
NR Racing 4* timing key (brings PVL up to 33* total timing)
NR Racing Mikuni TM24 flat slide carb kit/intake
Mikuni fuel pump
ARC Racing chain guard
ARC Racing top plate (with fabbed extension plate to fit Tillotson block)
NR Racing catch can
Hilliard Inferno Fire Clutch w/ 12t driver
RLV #35 gold on gold chain
NR Racing floating hub sprocket
72t rear gear
SUS header
RLV Modified silencer
15* PMR motor mount
Royal Purple 10w-30
VP110 fuel
Steering wheel:
PRC offset wheel
Seat:
Evolution size L
Brakes:
Sufficient
It’s a ripper! I’ve been able to run several laps on the original Burris slicks set up the kart came with. I just installed the new wheel/tire package this week and am looking forward to running some hot laps and sitting on the side lines for next weekends races! Ha!
Any thoughts, comments or questions on the kart and set up are welcome!
0B2265EE-A7A8-4DE2-8F68-C953F79C37C9.jpeg   E26BDDFF-4283-4326-BC1E-79266D81ABF4.jpeg
64985D8E-20A5-4102-AAF6-224282BE1974.jpeg   23355F91-628A-4A03-B2A0-89752157AF97.jpeg
Old 06-29-2020, 02:33 AM
landuse's Avatar
landuse landuse is offline
Looks like an awesome little kart!
WolfBuilt (06-29-2020)
Old 06-29-2020, 10:39 AM
Thelegg's Avatar
Thelegg Thelegg is offline
That looks like it's gonna be fun
Sent from my EML-L29 using Tapatalk
The Following User Says Thank You to Thelegg For This Useful Post:
Old 06-29-2020, 10:48 AM
Karts of Kaos's Avatar
Karts of Kaos Karts of Kaos is offline
welcome to the forum. it looks really cool! what is the top speed?
if it ain't broke I'll take it apart and fix it
The Following User Says Thank You to Karts of Kaos For This Useful Post:
Old 06-29-2020, 06:20 PM
Thx for the welcome guys!
As for the top speed, no clue. Only run it on the short 6.0 hear ratio set up for the 1/10th oval and I’m not even seeing the top of rpm range on it.
Maybe I’ll throw some old slicks on and a shorter gear to see what she can do some day.
